Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Help Needed: RS Flare measurements for OEM replacement flares
    Red face Removing RS Flares!
    I am removing my RS flares (they are already spoken for), but am in a bit of a pickle. I can't seem to find the seam for my flares at the top of the wheel arch. I thought I found it, but cut much too high for my replacement stock panels and in looking at the pics on the Pelican retail site, I think this is confirmed. Fortunately, I stopped cutting early enough to avoid needing to spend too much time undoing my handiwork.
    Does anyone have an uninstalled set lying around where you could throw a ruler on it and take a pic of the following dimensions?
    Thanks!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Dec 2006
    Las Cruces, New Mexico
    I do my friend, E-mail me.
    Early 911S member #166
    Just did. Thanks!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Done and done. Thanks, Mark!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Back from the garage; apparently I am not an idiot, because my cuts and marks are dead nuts to the drawing above. Final assessment? My damned stock flares were cut too short. F--K!!!
    So now I can go searching for another set of stock flares or try scabbing in steel for the 9" x 1" section that won't get covered.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Passenger side flare is off using these above measures. They were dead nuts based on post inspection; I pretty much hit the seams! Fit of the narrow flares is quite good; doesn't look like I will have to scab in much, if any, material. Some pics:
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    Looking good Kenik, looking good
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    Too bad Kenik,
    i had a good set available near Portland,they are now going overseas
    Update us when you proceed Kenikh, good luck!
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Looking good Kenik!!
    Great to see you going back to narrow body. I wonder if this will be common in the near future? Stash away all those narrow panels
    Matt Hart
    matthartcreative@instagram
    RHD 914
    1980 911SC (sold)
    69' T (sold)
    Early 911s reg # 994
  1. Battery box location measurements needed
    By endo911rs in forum Technical Info
    Last Post: 02-19-2014, 06:15 AM
  2. To flare or not to flare? 2013 is the question.
    By jpnovak in forum General Info
    Last Post: 02-26-2013, 07:16 AM
  3. Replies: 6
    Last Post: 05-23-2012, 05:05 PM
  4. OEM Steel Porsche 911 RS Flares or for ST Flare
    By SamBruni in forum For Sale: 911 Parts
    Last Post: 04-11-2010, 09:03 PM
