Thread: springs on throttle bodies
    I guess the returnsprings on my throttle bodies ('73 mfi) are worn.
    the throttle plates don't return to a full stop so the micro switch isn't engaged and the car starts running way to rich
    Is it an easy fix to change these springs? are they still available at porsche?
    or is their another cause...i read in some treads the throttle valve bushings could be worn?
    I don't want to spend to much on a rebuild of the throttle bodies because I'm building a new engine, so a temporary solution will work. Put an extra spring on the throttle linkage perhaps?
    Johan
    Quote Originally Posted by johan123m
    Johan
    Try WD-40 or penetrating oil on the springs/shafts before you get too worried. You'd be surprised how far a little lubrication can go on this old junk...
    If you still have problems after a good spritzing, then try lubricating all the ball sockets with grease - DO NOT ADJUST ANYTHING!!!
    -Marco
    TLG Auto: Website
  1. FS: 2.2S Throttle Bodies
    By rvdv in forum For Sale: 911 Parts
    Last Post: 04-09-2014, 03:31 AM
  2. WTB: Throttle bodies for 2.2S/E
    By clesch in forum For Sale: 911 Parts
    Last Post: 04-27-2012, 11:43 AM
  3. FS- Mag Throttle Bodies
    By advtracing in forum For Sale: 911 Parts
    Last Post: 01-23-2012, 09:29 AM
  4. throttle bodies
    By s-bonhomme in forum Technical Info
    Last Post: 12-28-2011, 04:38 PM
  5. which throttle bodies were used on the 2.5ST?
    By preS in forum Technical Info
    Last Post: 05-25-2010, 10:00 AM
