Results 1 to 7 of 7
Thread: Color Code For Red Fan Shroud?
    My game..saving Porsches FHernand's Avatar
    Jan 2006
    I am detailing my 67 S engine and need some help. Would you experts know what the color code, if any, there is for the red fan shroud? Before I go ahead and start tinting I thought some of you may have this code or, know where to obtain. I tried the 911 Red Book and found nothing. Addtionally, I checked the back of the shroud in hopes that there would be some sort of code but found nothing. The shroud is in okay shape. It has the usual cracks and ships but nothing major. I little fiberglass will fix the small cracks and such. Any help in finding the correct paint code for the fan shroud would be greatly appreciated. Regards, Freddie
    VINTAGE SPORTSCAR RESTORATIONS INC.
    www.vsrestorations.com
    Phoenix OREGON
    Freddie Hernandez
    freddie@vsrestorations.com
    (541) 535-3304
    www.facebook.com/VintageSportscarRestorations
    Senior Member BBausser's Avatar
    Jul 2004
    Sutalle, Ga.
    There not painted. Use some very fine grit paper, then polish with lots of elbow grease.
    Currently:
    67 3.6 Rocket "Silver"
    62 T6 Outlaw Coupe "ole Yellow"
    65 F100 Custom Cab Flairside Shortbed
    Gone but not forgotten in last 2 years:
    67S Concours King
    67 912 Vintage Racer
    68 912 Flipper
    83 911SC
    93 Mo30 968
    too many cars before that
    Early S Registry # 787
    R Gruppe # 551
    "its better to wear out then rust out"
    There was a thread about restoring these along time ago and I couldn't find it via the search engine.
    Bill is correct they are not painted but rather impreganted fibreglass.
    I did paint one very successfully but painter just tried to match the colour of the back where less fading had occurred.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Peter Kane
    '72 911S Targa
    Jan 2006
    Thanks for the help guys. I did find Chuck's write-up on the dye method. Is there anything Chuck does not know I will try this method on the backside and see how things go. Thank you.
    Phoenix OREGON
    Freddie Hernandez
    (541) 535-3304
    Jan 2006
    Here is the final look on my fan shroud. I added two coats of high temp. chem. resistant to keep clean and from fading. Thanks Chuck for the advise.
    Phoenix OREGON
    Freddie Hernandez
    (541) 535-3304
    Thumbs up
    Cheers Freddie........
    If I were to rewrite this article I would change the ratio to about a 3 to one solution of alcohol to dye, and get the shroud pretty damn intensely red before you polish. With cleaning and the general hot environment the red will fade over time. I've 'touched up' mine once in about 3 1/2 years.
  1. Replies: 5
    Last Post: 04-03-2014, 05:18 PM
  2. Fan Shroud Color
    By Hangman in forum General Info
    Last Post: 04-21-2013, 11:58 AM
  3. Correct colorname/code for red fan shroud?
    By teveo in forum Technical Info
    Last Post: 12-08-2008, 10:47 AM
  4. Shroud Color
    By gnus911 in forum General Info
    Last Post: 04-27-2008, 04:16 AM
  5. What color was the shroud on a 2.8 RSR?
    By racea911 in forum Technical Info
    Last Post: 01-10-2002, 01:43 PM
