Results 1 to 2 of 2
Thread: How to test a 1972 911 Tachometer
    Dec 2007
    East Coast, USA - Tysons, VA
    I have a spare (1972 manufacture) 7300 RPM 911S tachometer for my 1972 911T. The tachometer looks perfect, but I don't know if it works. Is there any way to test these things without actually installing them? If so, how do I do it? I'd just like to see if the needle (arm?) sweeps.
    If it ends up being dead (no movement of the needle/arm), what could be possible causes and who would be able to repair it (and how do would they do it)? I don't want to start off thinking it won't work, but you never know, and just in case, if it doesn't, I want to know what to do to fix it.
    FYI, I'm redoing my 2.4 liter engine to either S or E spec (or some combination thereof), which is why I want to eventually install this particular tach--apart from the coolness factor. For my engine rebuild, I have all the parts (Mahle 2.4 S and 2.2 E pistons and cylinders, and original S and E cams with MFI drive, and a 1972 911S 7300 RPM distributor). I wish I could decide which combination of P/Cs and cams I should use for the most fun on a street car so I could sell the extra stuff to someone who needs it.
    Thanks in advance for any info and advice.
    could you post a pic for your tachometer please i just bought one but now im not really sure if its correct for 73 S
  1. FS: SWB tachometer
    By OliveR in forum For Sale: 911 Parts
    Last Post: 06-21-2014, 11:02 AM
  2. FS: 911 E Tachometer
    By eprnjp in forum For Sale: 911 Parts
    Last Post: 11-14-2013, 05:56 AM
  3. FS: 10,000 RPM VDO Tachometer
    Last Post: 12-04-2012, 07:21 PM
  4. cost of compression test/leakdown test?
    By aknatar in forum General Info
    Last Post: 06-07-2007, 09:22 AM
