I need the rear engine tin (for 1969 - 1973) that is located under the fan which connects the two side pieces (no heater duct). Needs to be clean with no rust holes (already have that ). Need this sooner rather than later so if you have one please let me know....also does someone want a 68 engine tin that has the dimple for the smog with some minor rust holes?
Sam
