Results 1 to 7 of 7
Thread: VERY Early ID help needed
    I am not in a place with access to my prehistorical textbooks ... any help with dates would be greatly appreciated.
    Chassis # 304477
    Engine # 900458
    I believe it to be a 1966 911 but it may be a late 65 - I can't seem to find any definitive answers. The car has 4-screw grilles, center lube cams and originally came with Solexs. What am I missing?
    -Marco
    TLG Auto: Website
    Dec 2006
    Las Cruces, New Mexico
    Per Peter Morgan's book 'Original Porsche 911' it's a 66 with a 65 engine.
    Early 911S member #166
    I doubt that the 4 screw grills are original to the VIN mentioned. Now if the VIN appears to be 300447 than it is and it might even be a number matching car ..
    Richard
    I've seen stranger things, but I have to agree that the motor is from an earlier car...and who knows what else then?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Body - Engine #
    The 304477 is about April 1966 body.
    900458 engine is from 22 January 1965.
    (if you look below the engine type number the sequence number should be #358. If we talk nice - I could tell you the body it left the factory in)
    Let talk - I know someone looking for that period motor.
    Bob
    Early S Reg #370
    It would appear to have been built sometime in the April - May, 1966 time frame and probably should have an engine number beginning with "907.....".
    Check out this thread over on Pelican for some good info: http://forums.pelicanparts.com/showt...=232187&page=8
    For reference, mine is #302981 and was built in November 65 as a 66 model. It does not have the center lube cams, but is a Solex engine. It also has the four hole horn grill mounts on the fenders. My engine number is 903143.
    EDIT: Bob types faster than I do
    Quote Originally Posted by Bobs 67S
    I always talk nice. I sent you a PM.
    Thank you, gentlemen, for your help. I'm in the process of doing some digging to find out what I can about the car. I'll update when I know more...
    -Marco
    TLG Auto: Website
  1. Dimensions needed for early 911
    By NorthernThrux in forum Technical Info
    Last Post: 06-28-2012, 01:24 AM
  2. Early 911 logo needed
    By PDQ356 in forum For Sale: 911 Parts
    Last Post: 04-30-2010, 11:12 AM
  3. Early BBS Gurus - ID Help Needed
    By richemj in forum Technical Info
    Last Post: 11-28-2008, 11:39 PM
  4. Early 911's Needed
    By SandyI in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 10-15-2008, 01:03 PM
  5. early switch pic needed....
    By Rico in forum General Info
    Last Post: 10-15-2008, 09:42 AM
