Thread: 914/6 throttle lever mechanisim
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Does any know if there is a way around putting a throttle lever system in a swb 911.I was thinking a 914/6 unit might work;is there a similar 911 part that might work without the hand brake unit in a 911? ala 914/6..... Cliff
    Cliff...
    the 914-6 one actually has a rod in the tunnel that goes forward and pushes the accelerator lever on the pedal cluster....so when you lift up on the handle it pushes the rod...there is a little bracket that holds the rod in-place...can't remember but seems like the lever has a lip on it for the rod to hit....the 914-6 uses an accelerator cable and not a rod like the 911....maybe it would work...
    This part is rather hard to find
    Glenn Stazak
  1. 67s heat and throttle lever both on parking
    By MarkS in forum Technical Info
    Last Post: 02-19-2014, 04:29 PM
  2. Manual Throttle Lever
    Last Post: 10-05-2012, 11:35 PM
  3. Pic of 73S throttle lever parts
    By merbesfield in forum Technical Info
    Last Post: 03-23-2011, 06:34 AM
  4. WTB: Hand Throttle Lever and Knob
    By RTincher in forum For Sale: 911 Parts
    Last Post: 10-08-2010, 10:43 AM
  5. Hand Throttle Drag Lever needed.
    By aporschaguy in forum For Sale: 911 Parts
    Last Post: 07-16-2010, 09:44 AM
