Results 1 to 9 of 9
Thread: Upgrade "M" calipers with BMW 320i calipers?
    Ran across this interesting Pelican thread while pursuing an upgrade involving swapping my "M" calipers for "A's", with 84-89 struts and rotors. Anybody swapped an M caliper for one from a BMW? Awfully cheap, and gets you everything you get from the Carrera swap except the 20% thicker rotors.
    http://www.pelicanparts.com/techarti...W_calipers.htm
    Dec 2007
    East Coast, USA - Tysons, VA
    Thumbs up Easy Upgrade
    I have actually done this. It's basically a direct swap, very easy to do and makes a big diffference in braking. There should be no problems with the master cylinder, and the bolt spacing is the same (3 inches). The only issue is that, if you have vented rotors, you have to make sure to get the type of calipers with the spacers in the middle, which makes the slot broad enough to accept the thicker, vented rotors. Most of these calipers that I've seen will work on non-vented rotors only because they were used with thinner (nonvented?) rotors and do not have the necessary spacers.
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    That thread is about swaping 914 calipers with 43mm pistons with BMW calipers with 48mm pistons. 914 Calipers are not M-Calipers
    Odd to put a 48mm piston ATE caliper in place of another 48mm pison ATE caliper (M-Caliper)
    I am against that mod on a 914. This is not what I call an "upgrade". You're working with the same solid rotor you would have with the stock pistons. You're simply heating it up and warping it faster (if you're doing any type of performance driving). A stock 914 disc brake system, as simple as it may seem, is enough to throw your passenger through the windshield given the fact the system is in proper operating condition and has great pads. A simple 911 braking system is the same. A set of Porterfield P4S pads is much cheaper and much less labor intensive than mis-matching your brakes and components.
    Most people who think they are upgrading and feeling big differences went from a $hitty old worn, sticking 914 or 911 system to a new BMW system. We've done a "lot" of testing and asking professional drivers and the fact is, there has been no brake fade ever with one exception -- Serious Road Racing.
    That being said... there are some BMW 5-Series calipers which would effectively give you the same pad size as the S-Caliper/A-Caliper (they all use the 48mm pistons BTW) and mount on a 3" mount. It would be the same as the A-Caliper/3.5" strut swap (SC system with the 20mm rotor). This may be what M491 is referring to.
    James, are you road racing your 911?
    With struts and calipers so readily available... I think swaping a 3.5" strut assembly is the best bet, that's my $0.04 worth.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
    Dec 2007
    Yeah, that's what I was referring to. Sorry for the confusion.
    So its a 5 series BMW which might offer an ATE A or S size pad in a caliper with 3" centers, not the 320i?
    I'm probably headed toward the Carrera strut and caliper mod, not this one, but I found it an interesting and possibly very inexpensive option.
    Dec 2007
    Hang on...
    Wait a moment... I thought there was also a pre-1974 BMW 320 Ate front caliper that had bigger pads and a 3" on center bolt spacing that worked well on the 1969-73 911. Were these actually 5 series calipers? I believe it would make sense that these calipers, for the simple fact that they would lay a bigger friction patch on the rotors, would be an upgrade over the smaller M calipers (1969-73 911). Maybe I'm wrong... Dunno. Anyone know more about this?
    One year only 320i that is spaced to fit vented rotor, 1977/1978 I think.
    the others as mentioned fit 914 non vented.
    dunno of the 74?
    Jeff H.
    72 911
    914-6 GT
    320i wasn't produced until 1977, last of the 2002's in 1976.. I'm with our resident brake guru in UTAH. I'm dubious of the benefit is going with a similar size caliper just because. I've got the Volvo Calipers sitting in my garage that fit the 2002's and haven't changed them out because of this very idea..
    Bob Petitt
    1967 911S Coupe 307653S, my barn find - 55,000 miles Looking for engine #961269 and trans 901/02 #104337
    1971 911T Coupe 9111120264, my first 911 back in my garage
    1972 BMW 2002, my first car - 350,000 miles and counting
    1972 911T Coupe 9112100970, Sporto, parted it out..
    1983 BMW 320i, my everyday car - 138,000 miles and gutless
    2005 Subaru Outback, the daily driver - boring
    2006 Volvo XC90,
    Registry Membership #202
    Dec 2007
    Mild mannered disagreement...
    Respectfully, I disagree. I am certainly either wrong about the model or the year of BMW (I wish I knew), but the brake pads are much larger on the Ate calipers I used in replacement of my M calipers. I remember it being a rare, one year caliper. Rather, the caliper is not rare, it's the spacers between the halves that make it rare. The spacers allow the use of these calipers on a vented 911 rotor, and that's the rare part. Regarding the pad size, I'd compare it to the difference between a 356 pad and a 911 M pad. To my knowledge, if the friction pad is bigger, the braking effect will benefit greatly. This is why this is such a decent upgrade 9if you can find these calipers). It's a whole lot cheaper than swapping the struts and finding S calipers. Just my personal opinion...
  1. Replies: 2
    Last Post: 10-12-2012, 12:02 PM
  2. Replies: 3
    Last Post: 07-22-2011, 09:24 AM
  3. long "throw" normal on S calipers/brakes??
    By Kaleid in forum Technical Info
    Last Post: 05-12-2009, 04:56 PM
  4. "S" calipers and Koni struts
    By LUNARTI in forum For Sale: 911 Parts
    Last Post: 02-20-2007, 10:13 AM
  5. "S" aluminum calipers, KONI struts
    Last Post: 02-19-2007, 01:26 PM
