Results 1 to 9 of 9
Thread: Engine Bay Wiring Need Help
    My game..saving Porsches FHernand's Avatar
    Jan 2006
    I am getting ready to install my engine back in. However, as you can see form the picture, the wiring is a complete mess. Would you have a wiring diagram I can utilize to make sense of this wiring. Some leads are simply not used and others are broken etc. Any help would be greatly appreciated. Regards, Freddie
    VINTAGE SPORTSCAR RESTORATIONS INC.
    www.vsrestorations.com
    Phoenix OREGON
    Freddie Hernandez
    freddie@vsrestorations.com
    (541) 535-3304
    www.facebook.com/VintageSportscarRestorations
    Haynes on the 911 should get you close. Is this car the 67?
    Jan 2007
    Portsmouth, RI
    Lightbulb Wiring Diagram
    911S wiring diagram from workshop manual:
    A little larger version makes it easier on the eyes and your mental health.
    Here, maybe one of these:
    http://members.rennlist.org/911pcars/WiringDiag.htm
    Sherwood
    old softie67S
    Feb 2007
    Sanibel Fl
    67?
    If that is a 67, it has a lot of none original parts, non original coil and cdi are the first things I notice. This is not a knock on your car, just a forewarning that you have to intergrate the wiring for cdi with the original wiring diagram in order to get it running again. If it has the original tach and it has not been modified, there will be an "intermediate unit" that generates the correct signal to operate your tach. There are a number of posts on this board and Pelican that discuss this issue and have wiring info. I believe John Cramer authored many and you might want to search for his posts. If you do not find what you need, I may have some of the posts boomarked and may be able to help you find what you need. Good luck, tom
    Tom
    67S soft rear window
    60 356 Cab
    70 914-6 3.2 short stroke twin plug
    05 Audi S4 Cabrio (commuter)
    05 Audi Alroad (family driver)
    Aprilia SR 50R (Sanibel scoot)
    Jan 2006
    Great, thanks for the diagrams. This is just what I needed to sort it all out. Tom, thanks for the imput.
    Phoenix OREGON
    Freddie Hernandez
    (541) 535-3304
    Jan 2006
    I would like to have a picture of your 67 911S original engine bay wiring panel? This would be greatly appreciated.
    Phoenix OREGON
    Freddie Hernandez
    (541) 535-3304
    Freddy,
    Here is everything I know about SWB engine wiring.
    http://forums.pelicanparts.com/showt...hreadid=252299
    Jan 2006
    John, thanks so much for the information. It's exactly what I had been searching for. Tried doing a search I could not come up with anything. Regards, Freddie
    Phoenix OREGON
    Freddie Hernandez
    (541) 535-3304
  1. Replies: 23
    Last Post: 08-30-2012, 06:01 PM
  2. WTB: Wiring harness Fuse box to engine + engine - 1973
    By 911_2.2T in forum For Sale: 911 Parts
    Last Post: 10-24-2011, 01:03 PM
  3. 1969 Engine Wiring Help
    By MoparBoy72 in forum Technical Info
    Last Post: 08-26-2011, 04:58 PM
  4. Engine wiring
    By jim hahn in forum Technical Info
    Last Post: 01-23-2002, 08:06 AM
