Results 1 to 2 of 2
Thread: Brake pads for biasing f/r on my SWB help needed
    Ive got a 68 912 w/ a 2270 TIV and ive gone thru the suspension w/ poly bushings, 21/27 mm torsion bars, sway bars, and have just swapped in an 82 SC front end which got new bilteins/decambered ball joints and monoballs. ive put on new vented rotors and rebuilt the calipers. now instead of putting in a proportioning valve, i'd like to know what pad combo i could start w/ to properly bias braking w/ my set up w/ the new front end while staying w/ the 68 rear calipers? btw, intended application is street and occasional AX/DE. pagid yellow RS-19 (i think this replaces the orange RS-4-4) / pagid blue RS-4-2?
    thanks in advance
    68 912 - R inspired - 2.0L-4 turbo 18psi
    RGruppe #455
    S Reg #1539
    Senior Member Neunelfer's Avatar
    Dec 2002
    Sandy, Utah
    Tough call.
    You have L-Calipers with solid rotors on the rear? It's hard with those rear arms. I'd say find a caliper solution but... it's tough either way.
    Check with the manufacturer of the pads you're looking at. If you want a more aggressive rear pad to make up for the fronts "be cautious". Some times a more agressive pad can take a longer time to warm up and work. In normal driving conditions they may actually work "worse" than expected.
    I'd be tempted to simply match the pads and see how it performs.
    Eric - Sandy, Utah
    71 911
    914-6/GT
    914-6/ORV
    87 944 Spec 1
    Porsche Truck
    62 Beetle
    80 VW “Caddy” Pickup
    72 R75/5 Toaster Tank
    PMB Performance
    Love Us On Facebook
  1. Brake Pads
    By shipard in forum Technical Info
    Last Post: 08-14-2015, 08:57 PM
  2. WTB- PAGID brake pads
    By Chuck Miller in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 02-25-2012, 04:02 PM
  3. choice of brake pads?
    By RPMClassic in forum Technical Info
    Last Post: 03-26-2008, 04:46 AM
  4. Brake Pads
    By Chris Tallon in forum Technical Info
    Last Post: 01-03-2006, 05:24 PM
  5. Brake Pads
    By pwd72s in forum Technical Info
    Last Post: 03-23-2001, 06:17 AM
