Results 1 to 8 of 8
Thread: Muffler - Gray Paint
    Does anyone have a recommendation on high heat muffler paint that matches the original gray?
    Patrick
    67 911S
    I think VHT makes Ceramic in a can. It's basically a high-temp gray paint with ceramic particles in it. It makes a mess on the ground when you paint with it, but it looks pretty good when all's said and done.
    If you can get it to lay down well it'll look good and last a while.
    -Marco
    TLG Auto: Website
    Regis turd ab user
    Dec 2006
    Tacomatose, Wa USA
    Eastwood stainless grey is very close if not right on.
    Buy the one quart can, apply with either foam brush or spray and can be touched up.
    Muffler Paint
    I Went Through This Earlier This Year.stoddard Used To Produce Muffler Paint Back In The Day.i Used Vht Sp-104 Gray Flameproof Coating.see Performanceparts.com.i Started With A New Dansk Sport Muffler Two In Two Out In The Center.i Stripped The Whole Muffler To Bare Metal.washed It Down With Lacquer Thinner And Painted Per Instuctions,light Coats,let Dry Throughly Between Coats.install On The Car And Run To Operating Temp To Cure,let Muffler Cool And Do It Once More.coating Is Very,very Durable For The Cost Of Two Cans.
    Senior Member tfmcmahon's Avatar
    Jul 2003
    Tucson,AZ
    results
    Here is what th VHT looks like when you`re done.I used the primer and then the gray and cured it on the car per instructions.
    Member:S Registry #864
    Senior Member jloucks388's Avatar
    Oct 2006
    Walnut Creek, CA
    VHT Primer
    I found that VHT primer provided the best color match to original gray..
    -Jim
    '72 911T
    '02 B5 S4 (RS4 Clone)
    '12 997.2 Turbo Manual
    '19 B9 RS5 (Daily)
    Feb 2005
    Montreal, Canada
    Vht ?
    where do you get VHT paint ?
    Jul 2003
    Tucson,AZ
    Paint
    They are in Scottsdale! Good place to test high heat paint! Here is link to phone number.Their VHT site is down as of this morning.Be sure to get the primer as well as the paint. Tom http://www.macraesbluebook.com/searc...company=600590
  1. Slate Gray paint codes throughout the years?
    By LeftFootBraker in forum Technical Info
    Last Post: 09-03-2023, 05:09 AM
  2. Muffler paint
    By Cornpanzer in forum General Info
    Last Post: 01-26-2015, 05:03 AM
  3. What paint to use for muffler and heat exchangers?
    By Longballa in forum Technical Info
    Last Post: 02-08-2014, 12:34 PM
  4. Muffler Paint
    By 71-911T in forum Technical Info
    Last Post: 01-06-2008, 03:32 AM
  5. muffler baked paint
    By Shawn in forum General Info
    Last Post: 02-01-2007, 12:02 AM
