Thread: Disabling the flashing hand brake/brake pressure warning light
    Jun 2008
    Main Line, PA
    I have no desire to fix it, just to disable (especially the clicking). If I pull the bulb will the clicking go away too?
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    Yes ~ I just did the reverse of that Mine was not working and with a fresh bulb ... cilcking and light
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
    Senior Member karlusmagnus's Avatar
    Aug 2005
    NY
    Ron, it sounds like a bad ground, and as long as the bulb is there, you will hear clicking. Taking out the bulb should eliminate the clicking, if that is problem.
    You can try then to clean the ground, put back in the bulb, and clicking should have stopped. Using the wiring diagrams will help to follow what's what.
    Here are the wiring diagrams (courtesy of sherwood lee ;-)
    http://members.rennlist.org/911pcars/WiringDiag.htm
    '72T Coupe - Sepia Brown
  1. Blinking brake warning light
    By rpc356 in forum Technical Info
    Last Post: 06-16-2012, 04:02 AM
  2. Hand Brake Switch - light
    By drwhosc in forum Technical Info
    Last Post: 07-27-2009, 05:47 AM
  3. Hand Brake Light Issue
    By joe912 in forum Technical Info
    Last Post: 10-30-2006, 11:07 PM
  4. Hand brake Blinking Light?
    By jtkkz in forum General Info
    Last Post: 11-12-2004, 12:13 PM
  5. Hand Brake Blinking Light?
    By jtkkz in forum Technical Info
    Last Post: 11-11-2004, 05:39 PM
