Thread: Just back from the soda blaster
    Restoration newbie.
    Jun 2007
    San Francisco
    Here's my crankcase and cam towers just back from
    the soda blaster, I'm pretty happy with them althrough
    they still need the final 1% cleaned.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Andy,
    Looks good, but I would definitely return the parts to the soda blaster and ask him to finish the job. You have oil residue inside the cam towers and some areas of the case that still have oxidation.
    I used to run a soda blasting business in the early 90's, there should be no harm done to the aluminum, even with the more agressive grades of bicarbonate. Also, dry strips faster than wet, I wouldn't worry about cranking up the flow and really working the case over. The good news is that bicarbonate is soluble in water, although I would pull the case plugs and clean just to be sure.
    That said, I had my case tumble-polished by Ollies in ceramic media. They then pull the plugs and completely clean the interior oil passages. No worries that way and nice, no? I also had them surface and tumble the cam towers to remove any trace of the brown oil stains inside. At the same time they pull the spraybars and will add more holes (a '67 mod) if required and replace with plugs.
    Another pic of the internals, note case webs.
  1. Soda blasting
    By tar356 in forum General Info
    Last Post: 02-25-2010, 02:29 PM
  2. Cheap Soda Blaster
    By kissov356 in forum Technical Info
    Last Post: 02-26-2009, 01:45 AM
  3. S calipers cleaned with Soda
    By WM711 in forum General Info
    Last Post: 01-22-2008, 05:35 PM
  4. FS: MSD 6AL w/Blaster Coil
    By Mr9146 in forum For Sale: 911 Parts
    Last Post: 07-16-2007, 07:02 PM
  5. MSD Box and Blaster Coil Wiring Question
    By gruen911 in forum Technical Info
    Last Post: 01-28-2005, 05:55 PM
