Thread: RS Flare Measurement
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    Can anyone please tell me what the measurement is from the centre area of the flat outside lip of the flare to the corresponding area of the inside body work?
    I.E. the inner bodywork on the inside of where the wheel sits.
    I hope this makes sense! Body work guy wants to get it right
    Cheers & thanks
    Cam
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    Cam,
    If I'm understanding you corectly...
    My car measures 11 3/4 inches or 30mm from where the tape measure hits the inner wheel well over the tire to the middle of the outside of the flare...
    BTW - My car differed about 3mm less (about 11 11/16 = 27mm) from side to side...
    It will be interesting if more responses come with different numbers...
    Hope this was it... hope this helps
    Here's an old pic...
    Cheers
    RS Flairs
    Mine measure 11 1/2 inches flair to body both sides at the top of the tire. We need someone with an RS to give us some measurements.
    Mike
    Early 911S Registry #880
    356 Registry #30248
    1973 911S 2.7 RS spec
    1973 911T
    1964 356C twin plug
    1969 Z28
    I believe the measurements that Chuck and Mike have provided are both correct. i.e. about 11.5" to 11.75". Because these flares were welded on at the factory or later they are not all exactly the same. When my '73S was flared in the early 1980's the guy installing them widened them approximately 1" to fit race tires and my flares measure 12.5" (exactly) on both sides and the difference is noticable. (See picture). So if you are going after a stock look I think you want to be in the 11.5" or slightly wider range.
    May 2006
    Adelaide, Australia
    Thanks guys
    Information goldmine as always
    '74 RS 3.0 Replica
  1. To flare or not to flare? 2013 is the question.
    By jpnovak in forum General Info
    Last Post: 02-26-2013, 07:16 AM
  2. Looking for a measurement
    By jameshtaylor in forum Technical Info
    Last Post: 03-29-2011, 12:14 PM
  3. Chassis measurement diagram
    By Harvey Weidman in forum Technical Info
    Last Post: 02-20-2011, 01:12 PM
  4. Momo Wheel Measurement
    By 50/50 in forum Technical Info
    Last Post: 10-14-2008, 10:13 AM
  5. Antenna Hole Measurement Help?
    By FHernand in forum General Info
    Last Post: 11-06-2007, 06:15 AM
