Results 1 to 8 of 8
Thread: FS: 84mm 2.2S Pistons
    I bought these used pistons a while back for my 2.2S restoration. Well, the case was machined for 90mm P&C's so these are up for grabs.
    They were checked out by Henry at Supertec and given a passing grade.
    Looking for $500 + shipping
    Regards,
    Andrew M
    P&c
    I will take them if you can add the biral cyl (understanding for a higher price)
    Olin
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Unfortunately, I don't have the biral cylinders for them
    I was planning on using a set I had on the shelf, but it turned out they were cast iron T versions.
    The pistons are size 0 if that helps locate a set of matching cylinders.
    Regasrds,
    AM
    pistons
    interested if Olin passes.
    thanks
    kevin
    66' 912 Coupe - Sand Beige
    62' 356 Coupe - GT Racer
    62' 356 Coupe - Project
    pass
    I will pass to the next party since I would need the cylinders also
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Dec 2006
    Las Cruces, New Mexico
    Andrew please advise if Kevin passes. Mark S
    Early 911S member #166
    pistons
    Andrew,
    Sorry,
    I have to pass as well to Mark S.
    thanks
    disregard pm.
    kevin
    Dec 2006
    Andrew, you have a PM. Mark
  1. FS: Set of 6 84mm 2.4S Pistons and Cylinders
    Last Post: 01-17-2011, 05:57 AM
  2. FS: 84mm 2.2S Pistons
    Last Post: 11-03-2008, 12:28 PM
  3. WTB: 84mm forged pistons
    By ajwans in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 10-28-2008, 07:32 PM
  4. FS: 2.2S 84mm pistons w/ Biral cylinders
    By kenikh in forum For Sale: 911 Parts
    Last Post: 06-03-2008, 10:13 AM
