Results 1 to 10 of 13
Thread: '73 Heater Valves - Correct Color?
    Guys,
    What is the correct color for the (red) 1973 heater valve assemblies? Also, are they supposed to be shiny or matte in finish?
    Ideally, I would like to find an off the shelf spray can color that's close in hue, however I can also mix up paint and spray with my gun.
    -chris
    Jul 2003
    Santa Cruz, CA
    I just pulled mine recently off my 70. They are more of a brick red and definitely a matte, satin at the most finish.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    I used Dupli-color red oxide primer and then sprayed a little clear over that to give just a little gloss.
    Jul 2003
    Santa Cruz, CA
    Here are a couple of photos of mine. Haven't cleaned them up yet.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Right on. Thanks Guys.
    In case it helps, I did our last set for resto in black, but will do the next in red.
    Alan
    Jul 2003
    Santa Cruz, CA
    Alan, are the original cork gaskets still available or did you use a rubber alternative?
    I've been to lazy to check with PNA to date.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Hi Michael,
    These were bought from Porsche and are now a clear plastic version.
    HTH
    Alan
    Jul 2003
    Santa Cruz, CA
    Thanks Alan,
    I might just cut my own out of cork, though my originals are in pretty good shape.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Senior Member SpawnyWhippet's Avatar
    Mar 2013
    San Francisco Bay Area
    Does anyone have the part number for the heater hose shown in Alan.uk's pic? Replacing my entire heater control assembly at the moment and there seems to be very many different versions and colors of hose around.
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    2008 Cayenne S (sold)
    2004 Cayenne Turbo (sold)
    2009 997 cabriolet (sold)
    2002 996 Turbo (sold)
    1998 Boxster S (sold)
    1997 993 cab (sold)
    1989 911 3.2 Carrera (sold)
  1. Heater control valves
    By Norm01 in forum Technical Info
    Last Post: 02-19-2013, 10:11 AM
  2. Heater control valves
    By Norm01 in forum General Info
    Last Post: 02-18-2013, 06:11 AM
  3. FS: 72/73 door mirror and 65-68 heater control valves
    By fourteenten in forum For Sale: 911 Parts
    Last Post: 10-18-2007, 10:03 AM
  4. Color of heater control boxes
    By fourteenten in forum General Info
    Last Post: 08-07-2007, 09:10 AM
