How does the skid plate mount? From these photos, it looks like the case must be drilled and tapped?
Oh, so that is part of the few things you are doing before our trip.
Scott H.
1969 Coupe LtWt
1973.5 911T
Anybody??? I'm basically trying to figure out if it is a direct bolt-on to the engine case or were there some sort of brackets between the skid plate and case? Thanks.
CurtOriginally Posted by CurtEgerer
Is that a factory skid plate? Is it steel or alunimum?
Ask the man who owned the car! There were small L brackets that bolted to the engine case. Nothing was drilled or tapped. It all bolted to existing engine hardware points. Unfortunately I no longer own the car so I can not measure for you.
Don
found this on Edmond Harris's website
Nick D - Run Flat
1973 RHD 911 Carrera RS #0358 - Fun Car
2016 Cayenne Diesel - Tow Car
2017 Macan S - Better Half's Car
1955 356 Speedster SOLD
1976 911 2.7 SOLD
2006 Cayman S SOLD
2006 Cayenne S SOLD
2008 Carrera S F77 SOLD
2011 Cayenne S TOTALLED (T-Boned but kept us safe)
2015 Macan S SOLD
2015 GT3 - Track Car
2016 Cayenne SOLD
2016 Cayenne GTS TOTALLED (Bloody big deer)
Still looking for 1st Edition Carrera RS book #358.
Life is way too short to drive boring cars.
does it really make sense to do that?
on impact wouldn't the stress taken by the plate just be transferred to the case anyways?
Erik
Early S # 1107
All my german equipment is either busted or sold...sigh....in the market for a decent non-sunroof tub!!!!!!! Help me get back to autocrossing!!!
I guess the exhaust will also be somewhat damaged on impact, so I suspect this is to guard from rubble damaging the engine moreso that saving the engine on impact after a aerial excursion !
Nick D - Run Flat
1976 911 2.7 SOLD
2006 Cayman S SOLD
2006 Cayenne S SOLD
2015 Macan S SOLD
2016 Cayenne SOLD
Finally, he chimes in. I guess I should have called Thanks. That's what I need to know.Originally Posted by Rennman
Nick - thanks, that makes it easier.
Others - I will put this to the test on some cattle grates at this year's Iron Bottom, er ... Targa California ... and report back. Last year I just heard LOUD scraping noises.
Would you be willing to post the specs for the skid plates?
They look like a relatively simple fabrication.
I’m not going to entertain asking what the NOS ones cost at Edmond Harris.
R/
Sumner
Registry Member #970
1970 914-6
Adriatic Blue
1972 911T (vice)
Gemini Metallic
1967 911S (vice)
Slate Grey
