Results 1 to 10 of 11
Thread: Calling All Pedal Police
    I'm about to remove and rebuild a set of pedals from a 72T for use in my 71T. Is there any major difference between the two (asking mostly because of the 71 clutch system versus 72)? Anyone got any tips or tricks for rebuilding/upgrading and maybe some proud moment photos I can work from? I'm sorta preparing several winter projects for my whacko obsession but it's gotta beat knitting quilts....
    Paul Schooley
    S Reg #863
    R Gruppe #330
    Paul,
    I'm about to tackle this one also on my 69T. Try chasing down "Shawn 69E" as I know he had a pedal set for sale that he did new bushings etc.
    Paul
    Paul
    83SC, bone stock (not so much anymore)
    69T, 2.8 RS spec, MFI (Sold, but not forgotten)
    "Wailing Wench"
    s reg. #1009
    rgruppe #506
    Thanks Paul. I don't seem to come up with a good search here for this subject but I'm probably not using the right search string. Will try again. I'd like to rebuild the ones I have so I know the inner working of the pedal set.
    Paul Schooley
    S Reg #863
    R Gruppe #330
    Feb 2003
    Los Angeles
    Hi Paul,
    Pelican has a good tech article on the rebuild. See the link below:
    http://www.pelicanparts.com/techarti...al_cluster.htm
    It wasn't that hard. Just hard to get to. Your knees will be hurting at the end of the day.
    Good luck.
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    I just did the pedal cluster on my 67 and followed the Pelican tech note. It really was not tough at all. It took three hours not including the bead blasting and painting.
    Patrick
    67 911S
    The pedal assemblies are identical.
    -Marco
    TLG Auto: Website
    Thanks fellas...should make for a great way to pass time in the winter rebuilding one to perfection. That Pelican article is well done. I really need to spend more time over there skimming the tech forum.
    Paul Schooley
    S Reg #863
    R Gruppe #330
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    For durability go powdercoat or POR15 the rattle can paint will be damaged by the time you finish replacing the bushes.
    I used the POR-15 as well and the pedals look great.
    Patrick
    67 911S
    Aug 2003
    Van Nuys, Ca
    Clutch actuation shaft is different between a 70-71 and 72-75
    otherwise the same for the rest
    Member #755
    Conda Green 70 911S
    70 black 914-6 3.2
    70 911 "Speedster" project
    "74 IROC" tribute Jade Green RSR
  1. H1 vs. H4 - Calling Light Police
    By jaudette3 in forum Technical Info
    Last Post: 09-11-2012, 06:26 PM
  2. Calling all Fuch police
    By popowitz in forum Technical Info
    Last Post: 09-05-2011, 06:37 PM
  3. Calling the Seat Police: What are these?
    By 304065 in forum Technical Info
    Last Post: 04-25-2010, 03:18 AM
  4. Calling the Seat Police
    Last Post: 05-01-2006, 04:33 PM
  5. Calling the Fog Lamp Police
    By Sacto S in forum Technical Info
    Last Post: 03-24-2005, 10:25 AM
