Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Extreme hardcore head porn!!!
    Wink Extreme hardcore head porn!!!
    Double entendres aside, the title is no lie. Check out my newly CNCed heads for my 2.3L ST motor. Sick flow and unreal velocity...ovaled, offset and 'D'ed ports, sick internal contours, you name it. These heads are going to make crazy power all over the powerband. This is what Steve Weiner and Dick Evelrude come up with when they get bored.
    For comparison:
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    Very tasty Kenik
    What are the porting specs?
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    Nov 2003
    Sydney
    Kenik,
    ...do you really intend to get these dirty by actually using them ?...
    Seems a shame !
    Cheers,
    Dennis.
    S Registry member 536
    Apr 2004
    Sexy stuff !
    I guess I know where I will be sending my those heads now, eh Kenik ?
    Du must schwein haben
    901/05 #305701
    Bultaco Metralla 62 M8
    1968 BMW R69S
    Early911SReg #606
    Quote Originally Posted by kenikh
    So what company is that?
    cheers, Mike
    cheers, Mike
    Member#1664
    1972 911 S/RSR to Martini Prototype specification
    http://www.ddk-online.com/phpBB2/viewtopic.php?t=15294
    Quote Originally Posted by Mike_Moore
    cheers, Mike
    Steve Weiner is on this board as well. He is from Rennsport Systems (OR).
    Richard
    I wondered how long it would take before someone started CNC'ing 911 heads. The VW industry has been doing it for 5 years +. You can now buy a set of brilliant VW heads for half of the cost of having them ported by a guru just a few years ago.
    How big are those ports Kenik?
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    Kenik,
    show us more of this project.
    al
    Al Kosmal
    the X-faktory
    Current projects; 69-911.5
    76S rat bastard---off to Germany
    1970 914-4...off to Wisconsin
    73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
    66 912 ...off to France
    71E 9111200979 ( gone to Paris..then to Corsica)
    77S (off to NY)
    Early S #1240
    RGruppe #669
    www.x-faktory.com
    These heads come in at about 38mm intake, 37mm exhaust, but not being round, it is hard to quantify. I had them ported to my displacement and cam specs, but am waiting to hear back from John Dougherty now that he has the flow numbers as to whether we need to touch up the cams. I want it PERFECT.
    The specs:
    Fully detailed 3R case (shuffle pins, squirters, light mooning, every oiling mod known to man, etc)
    85mm JE pistons @ 9.5:1 CR
    '69S heads - ported as shown
    Twin plugs (still debating which system to use)
    DC44 cams (custom grind; .490 lift at both lobes; 102 deg lobe centers)
    Titanium valve retainers
    RARE 47mm 4-bearing cam carriers
    Nickie cylinders
    Rebuilt 2 liter 'S' rods w/ ARP bolts
    Cross drilled crank
    Fully balanced internals
    Fresh 930 oil pump, with full race chamfer on the internals
    2.4S spec MFI pump
    38mm-ish (match bored) magnesium MFI stacks and TBs
    Lightened '69S flywheel
    Planned to be good for between 210 and 220 HP (crank) at 7800 RPM. Torque production should be the stuff of legend due to head and cam matching. Should be fun; the car is already running a fully built 901 gearbox w/ AFKQX short gears.
    Steve is also going to be in charge of the exhaust: custom Geroge Narbel headers with custom RennSport system muffler. This is the last part of the torque production special sauce.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Thumbs up
    Kenik,
    1st - With all the spam this site is getting it's lucky I saw your name on the title of this thread before it deleted it without looking...
    A word to all... PLEASE don't pic a sexual thread title or 'handle'. With all this crap we're getting it just makes job a bit harder then it needs be......
    2nd - VERY inpressive heads bud !!!!! .....
    I think of the simple machcanical stuff I did on my 2.7 rebuild that others have now done, and I can't help thinking that the head work we did still gives my motor a little edge on some of the others. And work we did was NOTHING like the work you've done....
    ... With the specs you've given it should be a bloodly rocket...
    3rd - How much do you figure the 'ready to run' car will weigh?
    Cheers and go'on'ya,
    Chuck
  1. Replies: 9
    Last Post: 02-12-2012, 02:33 PM
  2. Porsche porn in the car corral
    By EARLY911ZOO in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 10-17-2011, 05:54 AM
  3. 2010 GT3 RS - Extreme Truth
    By CurtEgerer in forum Other Porsche Passions
    Last Post: 01-14-2011, 12:29 PM
  4. SWB cast iron distributor porn
    By Fritter in forum General Info
    Last Post: 01-21-2009, 03:27 PM
  5. vin sticker porn
    By robmog in forum General Info
    Last Post: 05-01-2007, 07:04 PM
