Thread: Old Fuel Gum Up
    Old Fuel Gum Up
    I thought I would take a moment and show all the results of old fuel sitting in a Bosch fuel pump...so when someone says to you," oh it isn't any big deal leaving that old gas in there for extended periods of time"...well now you will have the proof that is does matter....many a fuel pump is burned up because of this...and fuel lines and screens clogged......the stuff just returns to it's tar like form....look at it on the end of the screw driver and holding up one of the impellers......it is nasty stuff and stinks.....only thing that will remove it is lots of carb cleaner or lacquer thinner.....
    Mar 2004
    Bettendorf IA
    How long has that fuel been sitting?
    Jay
    72' 911T-Sold
    74' 914
    Early 911S Registry member #1161
    Really don't know Jay.....came out of a roller that had been stored
    i'm told the boating crowd has found that this new ethanol mix stuff goes bad much quicker than the old stuff. not sure if this means gumming up or just 'stale'.
    Erik
    Early S # 1107
    All my german equipment is either busted or sold...sigh....in the market for a decent non-sunroof tub!!!!!!! Help me get back to autocrossing!!!
    Card carryin' member! mjmoran's Avatar
    Aug 2003
    Yep, I just went through a similar pump on my 71 E. Remember to be carful putting the pump back together...they are somewhat "tunable" by moving the top plate back and forth while pumping fluid through.
    Michael
    72 911S Coupe, Sepia Brown
  1. Replies: 3
    Last Post: 03-09-2013, 08:14 AM
  2. Replies: 0
    Last Post: 02-11-2013, 10:19 PM
  3. PMO fuel pressure control unit - return fuel line?
    By lkadams in forum Technical Info
    Last Post: 05-27-2012, 05:58 PM
  4. Wiring stock fuel gauge to fuel cell; need wisdom.
    By jameshtaylor in forum Technical Info
    Last Post: 11-10-2010, 06:18 AM
