Results 1 to 8 of 8
Thread: Factory repaint?
    Factory repaint?
    I´m stripping my ´73 targa for total body resto and repaint.
    Both "birth certificate" from Porsche and paint tag state Signal Yellow (5210/114) as original paint.
    However it seems that the first coat of paint is gloss (doesn´t look like typical primer but rather like proper top coat) in lighter shade of yellow, presumably Light Yellow (6210/117).
    This is clearly showing in several places (under paint tag on left a-pillar, front slam panel, front screen frame and dashboard area, possibly elsewhere too).
    On top of the gloss light yellow there´s Signal Yellow; both covered by satin black (with factory crayon body number on) in the dashboard area.
    The only logical explanation to me seems that factory has first painted the bodyshell in Light Yellow and then for some reason repainted it in Signal Yellow.
    Any other suggestions?
    1973 911T targa (9113510254)
    signal yellow & black
    M409 sportseats leatherette & corduroy
    M424 fuel tank 85 l with emergency tire
    M470 comfort equipment
    M473 front bumper steel with spoiler
    Ironic. I just looked over a targa shell that the COA calls out Light Yellow per the chassis number and yet the entire body has what looks to be the original paint under gray primer - and it is Signal Orange.
    Under painting
    Just to add to the conversation, some of the early Signal Red cars have a layer of orange under the final color. There was talk of Porsche having trouble getting to the desired colors so the factory paint shop fix was to under paint in a tint of the final color.
    Could it have been yellow was a hard color to get-to?
    Ferry Porsche had a blue 911 with some pre-production fiberglass parts and it needed to be repainted because the fiberglass and metal accepted the paint differently. In hindsight it looks like painting in the "old school" pigments could be a real bear.
    Bob
    Early S Reg #370
    Yellow is a very difficult color to get to cover - it is pretty transparent - in my experience.
    paint
    yellow and red is very transparent , and i know that all red Ferrari had pink primer where all others had grey primer.
    And fiberglass can be difficult to get same shade as metal, thats espesially fiberglass in the "old days" now its better , but aware that all fiberglass "live"and will twist and will be not look straight after short time
    i work with sculptures on wheelshttp://picasaweb.google.com/Jancarfactory
    This solved my mystery. My tangrine Trans Am car had signal yellow under the orange paint. The COA was tangerine and all of the body numbers were correct on that car. I had speculated that it was already painted yellow, an orange car order was taken and the tub reshot. Another interesting paint bit, the brown Jennings 67S had red oxide primer under that paint. The doorjambs and under the lids were so dry with overspray that Porsche obviously had a tough time painting that car.
    Don
    Feb 2005
    Lake Tapps, WA
    My original paint signal yellow targa had a yellow base primer...looked like light yellow. I suspect that there were difficulties getting the colors to lay down correctly and that is why there was a base coat layed down.
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
    Light Yellow
    I have talked with a painter about my light yellow and he is advising me to put an initial layer of white to brighten the yellow. Ideas about how the lt yellow cars started out.
    Olin - Member #1375
    1972 911T
    Original
    Options added
  1. Recommendations on repaint during slow restoration
    By lexatola in forum Technical Info
    Last Post: 12-31-2010, 09:25 AM
  2. Repaint experiences?
    By rs911t in forum General Info
    Last Post: 11-18-2008, 05:17 PM
  3. total repaint
    By cjmded in forum General Info
    Last Post: 02-20-2007, 12:03 PM
