Results 1 to 8 of 8
Thread: FS: Race prepped 2 liter mag case
    SOLD
    This case is fresh back from my machinist. Everything you can imagine was done to this case:
    • Case savers installed
    • Oil bypass modification
    • Shuffle pins
    • Very light mooning of the webs
    • Layshaft bearing modification
    • Case squirters installed
    Spigot bore is standard for 2.0, 2.2, 2.4 liter engines.
    1R/2R 'T' case
    Fully inspected and well within spec at all dimensions.
    This is a perfect case for any small bore application that will rev up to an 'S' redline. My reason for selling is that my motor is planned to rev to 8000 RPM and my mechanic suggest I get an aluminum case instead. My loss, your gain.
    Get the case for significantly less than the machine work that went into it:
    Asking $1000 + shipping
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Detail photos:
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Light,Nimble,Uncivilized
    Jan 2003
    Kenik,
    Sent you an email.
    Marc
    Marc
    '69 Coupe in Pastel Blau
    R#464
    S#1390
    Haven't gotten the email yet; might be a website delay.
    I could do a deal with my cams and add a nice set of rebuild 2 liter rods, if you use your existing crank. This case is perfect for building any nice motor that that uses the 92mm spigots. I would limit this case to be used in applications no higher than 200ish HP. I know that you can get Nickies w/ 87.5mm JEs into those spigots for a nice 2381cc short stroke or a long stroke 2.5. Either would give you one grunty motor.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Jan 2003
    I've got a call and an email into Berrnie to discuss my options.
    A short stroke 2.3 sounds interesting...
    Are the cams S spec?
    Marc
    R#464
    S#1390
    Kenik
    Sent you a PM
    Cheers
    Jeff Eelkema
    69E (project)
    S Reg #1431
    Aust TYP 901 #132
    PM back. Thanks!
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    This item is sold
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. FS: 2.4 7R case; completely race-prepped
    By Steve@Rennsport in forum For Sale: 911 Parts
    Last Post: 04-04-2010, 04:36 AM
  2. 2.0 liter alu case...
    By Homemade 911 in forum Technical Info
    Last Post: 04-29-2009, 08:31 AM
  3. 100 liter race cells
    By TRE Cup in forum For Sale: 911 Parts
    Last Post: 09-17-2008, 03:16 PM
  4. Replies: 7
    Last Post: 06-07-2005, 03:27 PM
