I Have a 72 Coupe. Car is having a baremetal repsray. I heard somewhere that it was not until '73 that the engine bay was sprayed same as exterior of car. Is this correct?
Derek
Derek
'72 911E 2.4 Coupe RHD - Blue
Engine comp:
72 satin/flat black, over body color, over undercoating, over primer.
73 body color, over undercoating, over primer.
The black paint I belive was brushed on.
If you use the search function for " engine compartment color " you will find lots of treads on this subject.
Early 911S Registry #931
1971 911 2.2T Coupe Tangerine
thanks John
Does this mean that for a 1970 S that the engine bay would be black?
RGruppe member 445
Yes, satin black over body color over undercoating over primer.
Thanks Zithlord.
A great help. Many (car people) have told me that the bay should be the color of the car. Most did that, I believe as the car is concours and it was their way of attempting to dis-credit it as that was the only item they could point out.
I feel sorry for the next expert that goes down that road.
regards,
RGruppe member 445
Satin/Flat black paint..
Bob Petitt
1967 911S Coupe 307653S, my barn find - 55,000 miles Looking for engine #961269 and trans 901/02 #104337
1971 911T Coupe 9111120264, my first 911 back in my garage
1972 BMW 2002, my first car - 350,000 miles and counting
1972 911T Coupe 9112100970, Sporto, parted it out..
1983 BMW 320i, my everyday car - 138,000 miles and gutless
2005 Subaru Outback, the daily driver - boring
2006 Volvo XC90,
Registry Membership #202
Mudi; I suspect that the black in your picture is quite faded/dried out and that the original was Satin. I base this on color movie and photos from the factory in the early 70's.
I would agree.. the car has been sitting outside and exposed for a few years..
Bob Petitt
2006 Volvo XC90,
not quite...
it will look too nice if sprayed -- that isn't factory
to be TRULY CORRECT, you must light BRUSH the black on, not spray it; and you must allow some of the Schutz underneath and some of the body color paint paint to show thru
this is best achieved by doing it the exact same way the factory technicians did -- have a couple of beers for lunch and then hang your bratwurst filled belly over the rear support and swing away drunkenly with a very lightly pigment loaded brush
