Results 1 to 10 of 12
Thread: Seatbelts
    Seatbelts
    I need new belts for my 1969 T but I cant deside what would be appropriate...should I go for the orig style or should I upgrade to the retractable ones? Do the retractable require a lot of modifications to install? Do they really look out of place in a early 911?
    B-b-buy Bushwood?!?!
    Feb 2003
    Topanga Canyon, CA
    I had retractable belts installed in my '69 E. They look fine to me. And since it's my daily driver, I chose comfort and safety over originality.
    Sandy Isaac
    '69 911E
    #543
    I put the retractables in both my 69 912 and my 71 911T. Easy install and much more comfortable!
    Mark
    Jul 2006
    Corvallis, OR
    I was pondering the same decision with my 72S. It's a very early one that came with the non retractable. After owning a 70T with the retractable ones I decided to use the retractable. They don't look bad and they work far better. It's one of the few things I'm going to do that's not original but I don't care because it's my car and I'm building it for me. Sometimes you forget that when your trying to do everything so damn correct and original.
    72S, 72T now ST
    Jan 2006
    Naperville, IL
    I still have my non-retractable belts in my E and I really have few problems with them. I am always the one driving the car, so the drivers side is sized perfect for myself. It can sometimes be a slight chore to explain how to adjust them to passengers; but I am never in such a rush that it is a massive problem.
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Jun 2008
    Main Line, PA
    I have non-retractable 3 points and they are pretty miserable to use. What is an available retractable 3 point that fits without mods?
    http://www.peparts.com/Categories.bo...ELTS%3APorsche
    these are the guys I have always used. Mounted them in my Targa in an hour or so. Coupes are easier since you do not need to modify (cut) the interior rear quarter for the seat belt.
    Mark
    I have also used Pepparts and I like the setup a lot, no modifications are needed, so you can go back to original at any point and with maybe 15 minutes of work. I aldo like th efact that they look sort of period, you can even order them with the Porsche plaque on the buckle. Here's a couple of pics of my setup.
    Henry
    I think I will go with the retractable.....I'm a pretty skinny so there is WAY too much fabric left over after "adjust" the orig 3 point belts. Does anybody recommend any vender's? I checked out the peparts guys...they seem pretty reasonable but is there anybody else?
    Peparts is the best
  1. FS-NOS Repa seatbelts
    Last Post: 07-02-2012, 11:11 AM
  2. 72-73 NOS Repa seatbelts FS
    By 66S in forum For Sale: 911 Parts
    Last Post: 09-30-2009, 10:15 AM
  3. Fs:seatbelts and screwdriver
    By 71-911T in forum For Sale: 911 Parts
    Last Post: 03-17-2009, 04:08 PM
  4. What seatbelts?
    By 1971S in forum Technical Info
    Last Post: 10-05-2001, 09:32 AM
