Thread: Hard Starting 911 S
    Hard Starting 911 S
    Hi:
    I have a 1970 911 S. It is hard starting, but always turns over. It has zero smoke, does not miss and runs really strong.
    Is it normal for an S to hard start or is something going on?
    Thanks for the advice.
    RGruppe member 445
    Define "hard starting". Does it crank over too long? Does it have trouble turning over? Carbs or MFI?
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Kenik:
    Factory MFI car. It always starts. It cranks for a while (longer than I think is normal) and then starts.
    RGruppe member 445
    Apr 2003
    Portland, OR
    Is your starting enrichment circuit operable? I know that when my CIS Cold Start injectis disconnected, the car is very hard to start and get running.
    Harry
    Member #789
    2009 MB C300
    I usually turn the key on but not to start, just to let fuel fill the accumulator
    (sometimes a little while) then up throttle and then a full turn of the key to start and it'll start...cold days a little longer to start...
    Also is your cold start functional?
    Richard aka le Zookeeper
    early reg #1128
  1. Starting to look like a car again
    By classic in forum General Info
    Last Post: 07-22-2017, 04:55 PM
  2. Hard starting once warm
    By Kiwi Guy in forum Technical Info
    Last Post: 06-14-2013, 07:25 PM
  3. Hard Starting
    By Edwin Ek in forum General Info
    Last Post: 02-14-2011, 08:57 PM
  4. Not Starting
    By shipard in forum Technical Info
    Last Post: 07-01-2008, 11:23 PM
  5. starting...
    By mjmoran in forum Technical Info
    Last Post: 11-07-2003, 10:45 AM
