Results 1 to 7 of 7
Thread: Spark Plugs Help
    Spark Plugs Help
    I found two Bosch plugs that work for my 1970 911 S. They are W3DPO and W5DPO. I do not know which is better or correct for my car., The W3DPO I have and they are platinum. I am waiting to get the W5DPO plugs from Pelican. They stated that they are not platinum.
    I have been told that I should not use platinum plugs in air-cooled Porsche's. Is that true? Should I stay with copper plugs?
    So, do we go 5DPO or 3DPO? Platinum or copper?
    Thanks for the help.
    RGruppe member 445
    John,
    The "DPO" designation tells you they are BOTH platinum plugs (old style). The new platinums are NOT to used in almost anything,...
    3's are cold plugs and best suited for track use and high-speed driving. 5's are hotter and recommended for city usage.
    You'll need to base your selection on the above information and I hope its useful.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Apr 2003
    Portland, OR
    Steve,
    While we are onthe subject of plugs. Which NGK would you suggest ofr Street with a bit of Autocross thrown in? I have some NGK BP5ES's on hand.
    Harry
    Member #789
    2009 MB C300
    Card carryin' member! mjmoran's Avatar
    Aug 2003
    Quote Originally Posted by HarryD
    Steve,
    BP7ES for the NGK...
    Michael
    72 911S Coupe, Sepia Brown
    Why not the NGK BP5ES?
    If these work do they need to be gapped?
    RGruppe member 445
    Quote Originally Posted by denson
    BP5's are FAR too hot for any air-cooled engine.
    Steve Weiner
    Rennsport Systems
    Portland Oregon
    503.244.0990
    Steve:
    Thanks for the help. I will us the Bosch 5's you recommended.
    RGruppe member 445
  1. 2.2 spark plugs
    By TZombek in forum Technical Info
    Last Post: 11-27-2012, 11:43 AM
  2. 73 S spark plugs
    By philip guiral in forum Technical Info
    Last Post: 03-03-2010, 07:03 AM
  3. Spark plugs---which?
    By Zeke in forum Technical Info
    Last Post: 02-16-2004, 09:18 PM
  4. Spark plugs for '73 S
    By jayzoll in forum Technical Info
    Last Post: 12-22-2003, 06:58 AM
  5. '73 S spark plugs
    By Plays with Cars in forum Technical Info
    Last Post: 05-22-2002, 12:52 PM
