Thread: smart suspension "inerters"
    http://www.racecar-engineering.com/a...ally-work.html
    It seems that these "inerters" work actively to provide a reactionary force to push the wheel down after they dampen suspension bump travel, thereby controlling the sprung mass movement to a minimum. It acts as a damper but not in a purely reactive, frictional way as in a conventional damper which slows both the bump and rebound of the wheel. Inerters help keep the wheel loads in control.
    When will I be able to run these on my 911?
    Let me figure this out first, then I'll get back with you.
    Sherwood
    Aug 2006
    Sonoma, CA
    For me.............
    the solution comes more quickly this way -
    inerter inverter what's a consonant anyway!
    johnt
  1. FS: Special Extended Hub 380mm "RS" "RSR" Thick Grip Steering Wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 06-06-2014, 12:47 PM
  2. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-17-2012, 07:56 AM
  3. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-03-2012, 08:51 AM
  4. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 02-18-2012, 09:24 PM
  5. 68 "hot rod" suspension -- request your input
    By Nordschleife in forum Technical Info
    Last Post: 09-25-2008, 09:42 PM
