Any leads on a used (no crack) or NOS dashpad for a early 911?
Hi,
I may have a lead on some new ones but I am not sure what to offer, but I know they will not be cheap. I am looking for NOS or perfect RHD versions, and found this potential lead for LHD.
Alan
PS. this was for the correct early removable speaker grill 69-73, and not the later Porsche produced single piece dash tops.
Alan,
I have tried an original replacement one purchased from Porsche in 1999 and one I recently purchased 2008 with poor results.
So I'm not too confident that Porsche has, nor can rectify this issue.
Let me know if you source a good one. Really need a perfect one as it's going on a real nice 73 RS.
Regards,
AJ
Hi AJ,
The new ones you bought from Porsche were they the type with a none removable speaker grill? If so, these are not a direct fit (or at least the 4 I have fitted didn't). They required new holes for the fixing studs. I have some pics of this if it helps.
I will ask some more questions RE the ones I heard about.
Alan
Alan,
They were the type with the removable grill.
Appreciate any news, will keep searching.
Regards,
AJ
Alan,Originally Posted by Alan.uk
I have the same dash (non-removable speaker grill) that I want to put in a 72. This was bought new from Porsche in the late 90's and I want to know what complications I may face. Could you please email me the pictures you are referring to - obrimberry at hunterbane dot com
Olin - Member #1375
1972 911T
Original
Options added
AJ-
The factory NOS one will fit "OK", we just did one. You need to enlarge the mounting holes in the steel dash a bit. Maybe a little heat and some cursing as to why the $1000 piece doesn't fit correctly and you're done !
Helps to have the windshield out....
Steve
