Results 1 to 8 of 8
Thread: Valve stem help
    Valve stem help
    I have the original fuchs for a 70 S it appears the valve stem hole is for a tubular tire. Is there a retofit stem for tubeless tires?
    Jan 2003
    UK
    the valve you need is a TR415:
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Napa parts has them, as there are 2 different stems with the same part number (skinny&fat) make sure you get the fat bottom one as pictured in previous msg. They do work, some tire shops will tell you that they will not stay in but they will.
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    I've been able to find some of these valve stems locally. My application is for some 4.5x15 Fuchs alloy rims.
    Is it advisable to use some sort of adhesive between the stem and the rim? Or should they simply be installed "dry?"
    Thanks!
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
    should be good without adhesive as long as you got the "fat" TR415 and not the skinny one.
    Your local tire shop can order them, no prob. If not let me know and I can send you a set from my local shop. I think harvey machines early rims for a perfect fit, but should work without the machining.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Harvey does machine them as does Zim's in Texas. Add to their charges, one has to tack on the shipping charge plus insurance. Harvey has said that he uses and recommends these valve stems for those who don't want their rims machined.
    - Neil
    Dec 2006
    Las Cruces, New Mexico
    Quote Originally Posted by Zithlord View Post
    Correct John, our p ant town NAPA store had a rack of 10 pair yesterday.
    Early 911S member #166
  1. Rubber valve stem, deep six?
    Last Post: 07-31-2021, 02:47 PM
  2. valve stem for outlaw (951 spare) rims?
    By haycait911 in forum Technical Info
    Last Post: 01-03-2011, 02:35 PM
  3. valve stem for fuchs rim
    By vintage83 in forum Technical Info
    Last Post: 07-01-2008, 09:08 PM
  4. Valve stem holders??
    By Semjon in forum General Info
    Last Post: 01-06-2006, 08:35 PM
  5. Fuchs valve stem hole size
    By kissov356 in forum Technical Info
    Last Post: 07-28-2005, 10:15 AM
