The motor was changed to 2.4 t before the car came from oceanside california, about 6 yrs ago. The whole car has been worked on except the engine and tranny - they both work fine but the carbs like to pop a bit - could use tuning
The following was done to the car in the last six years
Interior
headliner
seat covers
carpet
soundproofing
door skins
shift linkage (2 areas)
original shift knob
stereo - under dash, no cutting. - high end with 5 speakers
original porsche wood wheel
mint dash, gauges, wood accents
full chrome rearview mirror
new windshield, gaskets front and rear
Exterior
all new rubber gaskets around all glass , doors, engine compartment, body panels etc.
2 part epoxy undercoat
3 coats high build primer
silver paint
new signal lenses front and back
original orange porsche symbol/badge
bosch headlight upgrade with classic chrome grills
power antennae
new battery
hella fog lites
new porsche lettering, gold 911 symbol
all chrome upgraded with better used piecesr
all glass upgraded with better used pieces
all rubber body gaskets new
Mechanical
New front struts
all ball joints new
all rubber grommets new
all suspension taken off, stripped and epoxy coated
rebuilt calipers - stainless brake lines
new brake pads
stainless exhaust (1500.00)
Rebuilt starter
Rebuilt pedal cluster
Carbs rebuilt
carbs have pressure regulator for 5 psi
carbs have air/fume return system
special k&N filters (ugly home made rain covers)
Rebuilt alternator this year
high end coil and electronic points.
new mounts
new engine sound suppress matting
rebuilt chain tensioners with guards
clutch cable and plastic pivots new
Tools
jack
rear sway bar adjust tool
carb air intake measuring tool
carb fuel measure tool
fan belt wrench
Problems - popping out of top of a couple of carb barrels and a couple of small bubbles under paint - a couple on right side rocker, 1 right side door edge, small one on engine lid
The car drives well and is very presentable
Asking $22,000USD. The car is in Ontario Canada but I can arrange to take it to Buffalo for shipping in the United States (any importation costs to be paid by the buyer) Please PM or email questions. Thanks.
