Results 1 to 10 of 15
Thread: tires for 7R rims
    tires for 7R rims
    I just purchased two 7R rims for the rear of my 1970 S.
    I am using deep sixes in the front with the Michelin XWX 185/70/15 tires. The tires are made in 185, 195, 205 and 215 sizes. Does anyone know what would be a good fitting size for the rear? I have 185's on the deep six rear rims now and can use them on the 7R rims. Do I want to go to a larger size such as the 195 or 205? Some have advised that the 205's may rub. The car is lowered about one inch all around.
    Further, should I move away from the OEM Michelin tire so I can use 60 or 65 series tires on the car?
    Those Michelins cost a fortune. So, I must make sure that if I use them that I selet the correct size. They will not take them back after mounting.
    Thanks for the help.
    RGruppe member 445
    If you should decided to not go with your Michellins please let me know as I would be interested in purchasing them.
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    7R with Michelin XWX 185/70-15
    The XWX 185-70 will look great on the 7R rim. I would just take them off the deep sixes and re-mount them on the 7Rs.
    The XWX IMHO has the best looking side wall of any tire made (even a 275 GTB4 looks decent when wrapped around a nice set of XWXs from M. Bibendum) and is period correct for your C series S.
    As you point out, they also lack the stigma of low cost! And, 185-70 is the OE size.
    You should not encounter rubbing and so avoid the nausea inducing paint blistering so often experienced when fitting over-sized rubber.
    Early 911S Registry
    Looking for engine 960 168
    Looking for gear box 103 165
    Sep 2006
    Maryland
    Same question, but for a SWB, W/no flair. lowered about in. street setup.
    Rob Abbott
    7R on SWB
    Check this link:
    http://www.early911sregistry.org/for...t=tires+rimnot
    I cannot speak from experience but Henry Garazo started the above thread not too long ago that should prove interesting.
    Our 67 SWB has 205/60s (Bridgestone Potenza 950) on deep sixes and they don't rub. However, the sidewalls bulge on the rim and don't look too good to me aesthetically.
    Early 911S Registry
    Senior Member joegt3cup's Avatar
    Mar 2004
    Colebrook CT
    I sent you a PM
    Joe Annicelli
    Early 911S Registry #751
    Polo Red/Black 1967 Porsche 911S Coupe "Walter"
    Black/Red 1967 Alfa GTJr. Coupe "Nero"
    Italian Red 1994 Ducati 900SS/SP looks fast standing still
    Italian Red 1957 Gilera 150 Sport
    Ahhhh the sixties... I envision myself one early Saturday morning wearing plaid shorts, black shoes with white socks smoking a cigarette heading to the hardware store to buy a bag of nails.
    SWB cars are an acquired taste however once acquired theirs no turning back.
    I agree the xwx is a great tire. I have them on a 70S, and in case it helps on my sleeper 71T with deep 6s and 7Rs I run 195/65s up front and 205/60s on the rear. The stance looks like.....
    HTH
    Alan
    Regis turd ab user
    Dec 2006
    Tacomatose, Wa USA
    215/60x15 will get you the closest to the original diameter at a cost,
    fender rub no doubt, my 205's will if I drive hard, and price.
    A 185/70 on a 7" rim will perform differently than on your 6" deep sixes as the side wall will be held more vertically firm by the increase in width and actually apply more tire contact patch.
    And they will look OK (cool)!
    If you are using the same size tire as on your Deep 6's, why bother? Sell the 7R's and buy a new TV
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
    Jan 2003
    NW Indiana
    Here's my old '71S with 195/65 on Deep Six front and 215/60 on 7R rears. Used 5 mm spacers on the front and 15 mm spacers on the rear and had no fender rub.
    Brian
    '71T
    R Gruppe #299
  1. Found 4.5 x 15 rims Fuch Rims
    By xsurfer in forum General Info
    Last Post: 02-22-2013, 08:56 AM
  2. WTB: Eleven Hole Spare Tire Rims 'Outlaw Rims"
    By Dean911E in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 02-10-2013, 01:10 PM
  3. WTB: Eleven Hole Spare Tire Rims 'Outlaw Rims"
    By Dean911E in forum For Sale: 911 Parts
    Last Post: 02-07-2013, 08:40 AM
  4. looking for tires for 9X15 & 11X15 Fuchs rims
    By Perry911 in forum For Sale: 911 Parts
    Last Post: 06-26-2012, 06:07 PM
  5. 225/50x15 tires on 7" rims on 71???
    By jwillhoit in forum General Info
    Last Post: 03-26-2007, 02:08 PM
