Hello
I'm looking for product recommendations to clean the interior of my 73T. It seems to have a basically unrestored interior and I would like to keep it tidy without damaging the 35 year old vinyl etc.
Hello
You might want to clean everything using a good quality vinyl cleaning product like Meguiars and a SOFT BRISTLED nail brush. Work the cleaner in lightly with the soft bristled nail brush and wipe off the surface with a clean terry towel.
You will be amazed at how much dirt will come out of the grain of the original vinyl - use an old towel.
For tight corners use the same technique but with a SOFT tooth brush.
Just use light pressure with the brushes - you do not want to mar or scuff the vinyl.
Remember to rinse off your wife's toothbrush when you are done.
Early 911S Registry
Looking for engine 960 168
Looking for gear box 103 165
I would contact carcareonline.com. The owner, his name escapes me, knows everything about car care and has developed products. Wurth makes the best carpet cleaner and many other products that will help you.
Good luck.
RGruppe member 445
Leatherique. You will not be disappointed. Go to their site and read up before you buy anything else......
'73 914 2.0
'74 911 Coupe
'74 911 Targa
'78 924
'84 944
'86 944 Turbo
'88 930S M505 (current)
'96 993 Coupe (current)
'73 911T (MFI) (current)
'84 944 (current)
Early 911S Registry #1030
Contact Griots as well. I use the interior cleaner on lots of items. Very mild and works well.
Michael
72 911S Coupe, Sepia Brown
I use diluted simple green on all vinyl... Woolite's carpet cleaner on the carpets sprayed on and brushed in then vacuumed.
The interiors are very durable you'll see what I mean.
Stefan Josef Koch
RGruppe #194/SRegistry #1063
2015 Porsche Cayman S
