car came without tools and jack...are they the same as for a 73 911..
73 RS 1189
81 924 Carrera GTS
69S 2L HSR
70 914/6 2.5 L HSR
2008 GT 3 RS
78 512 BB, 2000 550 Maranello, 85 308 GTSi
63 AC V8 prototype
63 fuelie vette
62 e type roadster
32 Duece lowboy hot rod ex Sqeek Bell
Yes exactly the same
Clyde Boyer
Early S Registry Member #294
TYP 901 Register Inc #6
Hi Mark,
Yes the tools w/bag are the same, but the jack is different. When was your RS built? Knowing this will let you zero in on the correct bag style. There is quite of bit of good info on tools/bags on the site. The jack for an RS is a green dot Bilstein but is from a 914 so it is shorter than the one used on the other 911 models in '73. You will probably want to find a correct compressor also for the inflatable spare.
Brian
'71T
R Gruppe #299
Thanks Brian, you beat me to the exact post I was about to make....
Bahia Red '72 911S
Meerblau PTS 2019 Speedster
ES #333
thanks guys, production date 4/73...
by the way, car has P7 tires, what is vintage correct..
73 RS 1189
81 924 Carrera GTS
69S 2L HSR
70 914/6 2.5 L HSR
2008 GT 3 RS
63 AC V8 prototype
63 fuelie vette
62 e type roadster
Hi Mark,
With an Apr. '73 build date you are probably looking for a tool kit with snaps or you could also consider a bag with a string tie. Here you go.
Brian
'71T
R Gruppe #299
[QUOTE=fryardds]Hi Mark,
Mark,
I gave you all this same info when you called me over the weekend !!
[QUOTE=Baron]i know, thanks chuck...i forgot which one you said i needed!!Originally Posted by fryardds
73 RS 1189
81 924 Carrera GTS
69S 2L HSR
70 914/6 2.5 L HSR
2008 GT 3 RS
63 AC V8 prototype
63 fuelie vette
62 e type roadster
can anyone with an rs number in the 1100's tell me which tool kit came in their car...thanks...
73 RS 1189
81 924 Carrera GTS
69S 2L HSR
70 914/6 2.5 L HSR
2008 GT 3 RS
63 AC V8 prototype
63 fuelie vette
62 e type roadster
string tie.
Bahia Red '72 911S
ES #333
