I am looking for either a single or pair of nice condition clear Hella 128 'V' shaped lenses. Thanks for your help.
Are these reproduction lens? I notice the tabs on the lower part of the lens that I don't see on older, used lenses. TIA
Brian
'71T
R Gruppe #299
I have never seen those tabs and have have had many 128 lenses
these V lenses should only be used with the round bulbs ,
if you use the quartz bulbs they are designed for the lenses with the horizanal line pattern.
Thanks for the info.
Here is the light that needs a new lens. The one on the other side is a V shaped lens.
[IMG][/IMG]
Brian
'71T
R Gruppe #299
Why are you leaving Hella 128's on that car???? 65 to 68 only.... Notice the bracket right behind the light?
E
Hi Eric,
Good question. My thought is that since I don't have the matching color covers to go back in the bumper I would try to find a correct lens to make these lights look more presentable until I work that out. What is the significance of the brackets behind the light? Once I have a set of covers I will remove the lights and find a good home for them on someone's SWB car. Looks like I will have to have some license plate frame holes filled too at the same time.
Do you need a set of these lights for any of your SWB cars? If so we can work this out.
Brian
'71T
R Gruppe #299
I think those tabs are some kind of holder to prop the lenses up for photo. These lenses are available new for around $100 a pair, Hella brand. Yellow a little more. Try Retro Motor Works or Lunarlights on E-bay [currently $44 at Retro ]
Where are the lenses available from?
Steve
Brian,
I have an extra V lense I can give you. I will put it in with your wheels.
Perfect.
Thanks very much John.
Brian
'71T
R Gruppe #299
Brian,
I'm complete on Hella's right now, but thanks for the offer! See you in SLO.
E
