Thread: Rear Brake Cailper Removal
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    Anyone got any tips for getting the bottom bolt off without removing anything like brake pipes etc?
    Hard little sucker to get to! Do you use a special tool or anything?
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Cameron, Doing both my front and back as we speak, i had to remove the hard line to get in there.
    Have you found a plater in OZ or are you going the VHT / Powder route.
    Tony
    Restoration newbie.
    Jun 2007
    San Francisco
    IIRC I removed the bolt you can get to then rotated the caliper around
    the other bolt as far as I could. This gave me enough room to loosen
    the second bolt.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    May 2006
    Adelaide, Australia
    Classic
    Just wanting to get the hub off so I can install some longer wheel studs!
    No plating involved.
    Andy the bottom bolt is so tight I can't rotate the caliper.
    I might try grinding down an old socket....
    '74 RS 3.0 Replica
    Restoration newbie.
    Jun 2007
    San Francisco
    Quote Originally Posted by Cam Arnott
    "Rotate" may involve use of a big hammer.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
  1. Rear hub removal
    By Bob Harriman in forum Technical Info
    Last Post: 01-15-2014, 03:35 AM
  2. Hand brake lever plastic handle removal ?
    By mac73s in forum Technical Info
    Last Post: 12-14-2013, 01:22 PM
  3. Replies: 3
    Last Post: 04-22-2012, 06:07 PM
  4. Rear radius arm removal
    By plumber in forum Technical Info
    Last Post: 04-12-2011, 08:20 AM
  5. Front and rear glass removal
    By cmcfaul in forum Technical Info
    Last Post: 06-21-2010, 07:28 AM
