Results 1 to 10 of 13
Thread: Differences in 993 from 95-98?
    Dec 2004
    Is there a preferred year for the 993? What improvements were made of the span of the 993? Are there any consistant issues with the 993 in any given year or over the whole span?
    Thinking of making a '97 or '98 or other 993 maybe even a C2S my next Porsche and would like any insights people could offer. I'd even like to hear if there is another between the 993 and present that folks feel would have a good dollar for dollar value as a club event driver/ club concour type car. Something to just get in a drive.
    I saw the last 993 offered here and gae it some serious thought. Is that "the One" most folks would target as the best of the 993's? Very pretty!
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    Restoration newbie.
    Jun 2007
    San Francisco
    Porsche introduced Varioram somewhere in the 993 series.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Card carryin' member! mjmoran's Avatar
    Aug 2003
    first year 993s have OBD1 and later have OBD2 and vario ram. Therefore the earlier ones are easier to tweek from what I understand.
    Michael
    72 911S Coupe, Sepia Brown
    Dec 2004
    Varioram came in 1996-98 models
    From what I found, the VarioRam boost low end torq by as much as 20% and added 3% to top end.
    Are there any issues that a person should steer clear of with these cars? Any tell tale areas to look for if the car has been abused?
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    Restoration newbie.
    Jun 2007
    San Francisco
    A guy I know bought a 1997 993 just last year. He found rust in the
    lower left of the rear windscreen. It was just out of its 10 year
    corrosion warranty.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Dec 2004
    The more things change, the more they remain the same.
    I had to repair that every area on my '67 and now you're telling me I may have to do the same on a 1997. Shoot! That's not at all what I was expecting to hear.
    Thanks......I think.
    [SIGPIC][/SIGPIC]
    1967 911S Coupe
    1991 944S2 Coupe
    Past projects:
    1967 912 Coupe
    1969 911T Coupe
    1985.5 944 SR Coupe
    Quote Originally Posted by ajwans
    corrosion warranty.
    andy
    A sunny Los Altos Hills '95 993 that I inspected about 2 months ago had that same issue. Some one knows if it's an issue?
    Richard
    All 993s were hydraulic tappet motors = no valve adjustments.
    The 1995s were the only year without VarioRam (a personal favorite).
    The biggest problem with the VRam motors was their tendency to trip a Check Engine light due to clogging of the Secondary Air Injection passages. This light will prevent the car from being smogged and can "only" be cleared by doing a valve job ... yes, rebuilding the top end. However, there have been many attempts by independant shops to circumvent this problem ... some have been successful and others have failed. THAT is the biggest 993 issue.
    All 993s have fairly weak bottom ends that don't respond well to abuse. High RPMs are a NO NO with the 993 3.6 because of the poor quality of the rods ... failures tend to occur on the big end.
    993s don't leak much oil ... when they do it's usually from the valve cover gaskets and/or the oil filter on the back of the motor.
    Some 993s also had problems with squeaky windshields ... a problem from the factory that is easily cured with a re-seal. The rear window mouldings have a tendency to lift with age - this can be cured with either a)a new rear glass or b)a good glass guy.
    All in all the 993 is a GREAT car. However, they can get VERY expensive if you fall behind on your regular maintenance. The maintenance schedule is 15/30 - every 15 is a minor and every 30 is a major.
    That's all I can think of right now...
    -Marco
    TLG Auto: Website
    If you go to the 993 Forum at www.rennlist.com, this subject is discussed in great detail. Some people claim they can feel the extra HP that the Vram gives, some people, especially in CA, prefer the OBDI without immobilizer. The Vram enthusiasts claim that SAI port cleaning and changing the SAI valve solves the CEL issue.
    The '95's also has the 3rd brake light that looks like a basket handle on the rear of the car, most 993 enthusiasts are OK with it on a Cab, but the Coupe fans hate it and some remove it. The '95's also had some issues with the steering wheel and I think the early 993's ('95's and '96s) had a recall on the convertible top motor. Not sure about the years involved in the recall.
    Also, I think the HP difference is 12HP (270 versus 282) for the '95 non-Vram 993 and the '96-'98 Vram 993's, respectively.
  1. Value differences T vs S
    By RS-GT in forum General Info
    Last Post: 06-13-2014, 09:31 AM
  2. differences between 2.7 RS MFI and 2.4 S MFI
    By pacorron in forum Technical Info
    Last Post: 11-10-2011, 11:04 AM
  3. '70 and '71 911 differences
    By gulf908 in forum Technical Info
    Last Post: 04-14-2008, 10:11 AM
  4. differences between swb and lwb
    By jk356 in forum General Info
    Last Post: 07-12-2007, 11:19 AM
  5. 2.4S vs. 2.2S MFI -- DIFFERENCES?
    By NeedanEarlyS in forum Technical Info
    Last Post: 12-15-2003, 03:06 AM
