Thread: Source for undersized flywheel main seal?
    I've got a relatively small leak from my main seal that has already been replaced once recently. I am hoping that I can eliminate the problem with an undersized one but they are NLA. Guaranteed not leaking from the outside edges. Does anyone know of a source out there?
    Kevin
    seal
    I never knew they had undersized fly seals? However what is probably wrong is that you have a groove worn in the flywheel from the seal and a new seal will not help. You need to cut the seal just enough to clean it up or get a flywheel without a groove.
    If you have a groove worn in the flywheel on the seal area, you can repair it by installing a ready made sleeve available at bearing supply stores. It is a thin stainless steel sleeve available in a variety of diameters. It gives the seal a brand new surface to run on.
    Second on what Ed said. Stoddard's sells these kits. They do work. Had a oil leak in the rear main. After replacing the main seal several times with no luck. It was decided that it was either a mag case weeping(75 RS Euro motor with mag cases) or a worn crank. It was hard to imagine it was the crank since it was checked by the machine shop before assembly. However the sleeve seems to have done the trick. If I get a chance today I will try to look up the kit in the Stoddard's catalog.
    Bill Barnich
    R Gruppe Nr.230
    Early S Nr.960
    71 911T/2.7 Tangarine
    73 911?/3.6 work in progress
  1. 912 std. main brgs.
    By stphers in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 03-10-2011, 07:55 PM
  2. Newer style door seal fit versus old style seal
    By EsGeht in forum Technical Info
    Last Post: 12-03-2009, 04:56 PM
  3. FS: NOS Glyco .25 undersized bearings - Mains and Rods
    Last Post: 09-12-2009, 06:08 AM
  4. Hood Crest- Seal or no seal
    By neilk in forum General Info
    Last Post: 05-03-2008, 06:10 AM
  5. Replies: 24
    Last Post: 04-04-2008, 02:26 PM
