Results 1 to 10 of 10
Thread: WTB: steering bearing/ring/spring
    Dec 2004
    SE Michigan
    Need early steering column:
    -split ring
    -spring (these are <$2 new, so I guess this piece isn't a big deal)
    seen below...
    Bill G.
    1968 911 Ossi Blue coupe...restoration complete!
    EarlyS #718 | RGruppe #437
    Dec 2004
    SE Michigan
    Also, if someone could tell me if I need the rubber horn cuff for a Prototipo, that would be helpful.
    And new labels for the clamshell would be helpful too.
    Bill G.
    Dec 2004
    SE Michigan
    any help?.......
    Bill G.
    Apr 2003
    Portland, OR
    Quote Originally Posted by 911scfanatic
    My Momo wheel did not require the rubber cuff as it came with it's own horn button.
    You still need the Spring and Bushing on the part that connects to your steering column spline.
    Harry
    Member #789
    2009 MB C300
    Apr 2003
    Portland, OR
    Bill,
    I am thinking that "Bushing" (my term) and "Bearing" (your term) are the same thing. It goes on the end of the shaft (with the spring) that goes over the steering column spline. The lower picture above shows the spring/bushing combo I am refering to.
    Harry
    Member #789
    2009 MB C300
    Dec 2004
    SE Michigan
    o.k,
    1. the spring
    2. the split ring, or bushing
    The cup-shaped bearing (shown in the left pic) is actually pressed into my column.
    Bill G.
    Call EASY, that's where I got my missing split ring...
    They are also available new from Porsche.
    HTH
    Alan
    Apr 2003
    Portland, OR
    Factory part available again:
    Bushing Part#: 695.347.725.00.
    Spring Part#: 914 347 713 00
    Harry
    Member #789
    2009 MB C300
    Moved this historic thread to WTB…
    Peter Kane
    '72 911S Targa
  1. Steering shaft bearing
    By rdelmendo in forum Technical Info
    Last Post: 02-16-2016, 06:17 AM
  2. Steering Upper Shaft Bearing
    By Merv in forum Technical Info
    Last Post: 09-13-2013, 08:01 PM
  3. WTB spring ring on back of horn button
    By Tom F. in forum For Sale: 911 Parts
    Last Post: 06-02-2010, 02:51 AM
  4. Wanted: Oil filter O gasket spring ring
    Last Post: 02-23-2009, 09:39 AM
  5. WTB Upper Steering Shaft Bearing
    By kissov356 in forum For Sale: 911 Parts
    Last Post: 06-06-2006, 02:55 PM
