Results 1 to 10 of 11
Thread: Battery acid...or is it?
    I have removed my batteries to clean up what I thought was some minor acid residue. But, when I applied a baking soda paste, there was no bubbling that I expected. Is it likely that the white powdery substance is either not acid or is old acid residue that over time has neutralized. I recently replaced my old acid type batteries with the Sonnenscheim gel batteries so there has been not recent acid vapor present.
    Thanks in advance,
    Robo
    356Robo
    64 C Coupe #218448(sold)
    70T Targa #9110110416(sold)
    Apr 2003
    Portland, OR
    I noted the same thing in my box where I replaced my Interstate withan Optima. I too would be interested in the answer.
    My plan is to wire brush the mess, hit it with some EXTEND and paint it over.
    Harry
    Member #789
    2009 MB C300
    Nov 2002
    Worshington State
    Sorry to be the one to have to break the bad news, but you are seeing battery acid residue. Don't expect to see bubbling unless the acid is fresh.
    I had the same before I switched my lead acids out for an Optima.
    Clean it out and hit it with POR 15....that'll save your bacon
    Paul Schooley
    S Reg #863
    R Gruppe #330
    Paul,
    Thanks. I know that Por 15 works on rust, but it also works on acid residue?
    Getting a lot of water even near my car makes me nervous. I've taken off all of the loose paint/undercoat in the battery area and used brushes to loosen the white substance, vacuuming it out. So if I rinse with water, dry, and paint with Por 15, I'll be good?
    Rob
    356Robo
    Your car will be fine...you'll be a nervous wreck. I find a six pack usually calms the "oh my god...white residue under my battery" syndrome.
    Paul Schooley
    S Reg #863
    R Gruppe #330
    Paul,
    I totally agree with the beer part......Coronas with lime on top gets me through the day.
    So, if I flush the area with water, soak up excess with towel and use a hair dryer to completely dry, will I qualify for the truely rust foebic (sic?) 911 crazy?
    Rob
    356Robo
    Apr 2003
    Portland, OR
    What I do is:
    Wire brush the loose stuff off.
    Wipe it down with water followed by Isopropyl alchohol.
    Allow to air dry.
    Coat with EXTEND or POR-15 to encapsulate the rust. (FWIW Extend is less messy to apply than POR)
    Top with an Epoxy paint.
    Call it a night.
    Harry
    Member #789
    2009 MB C300
    Spray some acid over the rest of the chassis and you can say that your car has been acid-dipped for weight reduction- just like the factory race cars
    Not Really...
    Not an ad for POR-15...just learning by going to their site...
    http://www.por15.com/
    Looks like they have a three-step treatment method...
    Step 1 - Marine-Clean
    Step 2 - Metal-Ready
    Step 3 - POR-15
    Peter Kane
    '72 911S Targa
  1. New battery acid/distilled water mix
    Last Post: 03-04-2011, 11:50 AM
  2. battery acid leak protection
    By 356robo in forum General Info
    Last Post: 02-11-2008, 04:33 PM
  3. media blast or acid dip. pros/cons
    By X-Faktory in forum Technical Info
    Last Post: 08-16-2007, 07:40 AM
  4. Twin battery to single battery conversion
    By bulldog in forum Technical Info
    Last Post: 03-30-2002, 09:44 PM
