Thread: Engine Overhaul
    Senior Member 72911E's Avatar
    Jul 2006
    London / Fort Lauderdale
    Engine Overhaul
    I have found a nice rust free '73 car that requires a full engine overhaul.
    What do I need to budget for a stock overhaul of a 2.4T. Also, can u recommend anyone in the LA/San Diego area that can rebuild the motor?
    Derek
    '72 911E 2.4 Coupe RHD - Blue
    It would be best to budget for around 10K +/-. The reality is that it could easily get out of hand depending on shop labor rate, if you split the bottom end, and whatever hard parts you might need (i.e. case work, Ps and Cs, valves, guides, keepers, springs, bearings, etc.).
    I recommend that you work closely with the shop to figure out exactly what the engine needs and what it doesn't need. There are places you can cut costs and places you can't - a good mechanic can help guide you.
    -Marco
    TLG Auto: Website
    Besides Marco's good points I would like to add that the term "Rebuild" means many diffrent things to diffrent people. "Make it run again for once and awhile putting around" or "as new or better" will change the price considerabley, for example new timing chains and guides are a common part of a "rebuild" and that works fine alot of the time but any body who has played with drive chains, like on a dirt bike, knows that the chain and sprockets wear out togeather and putting new chains on worn sprokets will cut the life of the chains considerably so do you replace just the chains and guides for $120? or the chains guides and sprokets for $1200? depends on how the engine will be used and how wore out your stuff and how well and long you want it to run. So that is why the numbers are all over the place. Best case "fresh up" $3500.
    Good shop, replate and repaint every thing rebuild MFI, Starter, Alt., linkage etc to "as new or better" condition $20,000 Plus.
    but on average around $10,000 does it.
    henry/supertec or Jerry Wood
    do not use motormeister
    you mean Motormisery
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
  1. Replies: 27
    Last Post: 04-12-2023, 08:47 AM
  2. Engine overhaul-960029
    Last Post: 01-03-2014, 07:11 AM
  3. Is the fuel pump overhaul for 911 of 1973 possible?
    By naba901R in forum Technical Info
    Last Post: 12-27-2013, 10:40 PM
  4. Cylinder overhaul or new?
    By 67Porsche911S in forum Technical Info
    Last Post: 06-03-2009, 10:15 AM
  5. How To: MFI Electric fuel pump overhaul
    By kenikh in forum Technical Info
    Last Post: 04-25-2008, 08:37 AM
