Thread: T to S gauges
    T to S gauges
    Hi guys,
    I have a 1971T with standard gauges, which I wish to put the S gauges into. It is a LHD to RHD conversion.
    Is this a straight forward swap or will there be issues with the wiring loom and other components?
    Thanks in advance
    Ed
    Senior Member 911kiwi's Avatar
    Feb 2003
    Auckland, New Zealand. And Los Angeles, USA.
    RHD wiring loom?
    Should be straight forward if you have a RHD wiring loom. If it's the original LHD loom then you will most likely need to lengthen some of the wires. As I recall, gauges are arranged in same sequence L-F whether RHD or LHD. With the main loom running down the central tunnel, the wiring originally going to the "nearest" gauge is now going to the "furthest away" gauge - if you get my drift. Could involve lots of splicing. Good luck!
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Early S Registry # 306
    The conversion was done some years ago so the standard T gauges are already attached and in situ.
    Would there be additional wiring to lengthen?
    Jul 2006
    Washington D.C
    Can someone plese point to me what is the differences between the T and the S gauges?. Thanks. Andy
    Andy (VA).
    aT gauges are more basic and do not include oil level/pressure gauges but just a light.
    See photos below:
  1. FS: Gauges 930
    By Minkoff in forum For Sale: 911 Parts
    Last Post: 10-12-2013, 10:41 AM
  2. gauges FS
    Last Post: 12-01-2012, 04:34 AM
  3. WTB: 68'/69' Gauges
    By Bobboloo in forum For Sale: 911 Parts
    Last Post: 10-15-2009, 11:51 AM
  4. WTB Gauges
    By speedo in forum For Sale: 911 Parts
    Last Post: 11-06-2008, 04:59 PM
  5. WTB 'S' Gauges
    By Polizei in forum For Sale: 911 Parts
    Last Post: 10-17-2008, 02:09 PM
