what tires, (make and size), did the car come with from the factory in 73...she currently has p7's...thanks, mark
73 RS 1189
81 924 Carrera GTS
69S 2L HSR
70 914/6 2.5 L HSR
2008 GT 3 RS
78 512 BB, 2000 550 Maranello, 85 308 GTSi
63 AC V8 prototype
63 fuelie vette
62 e type roadster
32 Duece lowboy hot rod ex Sqeek Bell
Originally supplied with 185/70 VR 15 on 6Jx15 rims front
215/60 VR 15 on 7Jx15 rims rear.
The tires were Dunlop SP 57H or Pirelli CN 36.
Your particular car #1189 was supplied with the Dunlop option.
I believe it is now impossible to get both tire sizes in the same brand. Pirelli make a vintage 185/70 15 but do not make it in the larger size. You will need to go to a 195/65 15 on the front which gives the same rolling radius.
What size rims do you have?
Cheers
Paul
Early911S member #1398
50 356 Cab
57 356 Carrera
61 356 Roadster
73 RS #0073
79 930 Turbo
93 3.8RSR
Mark - see this previous thread on the same subject:
http://www.early911sregistry.org/for...=correct+tires
Andy
Early 911S Reg #753
R Gruppe #105
thanks paul and andy, i've got 7's and 8's, whats the closest i can get to the taller 'vintage" look...
73 RS 1189
81 924 Carrera GTS
69S 2L HSR
70 914/6 2.5 L HSR
2008 GT 3 RS
63 AC V8 prototype
63 fuelie vette
62 e type roadster
seems only fulda makes a tire in both sizes still, anyone have experience with the fulda 2000...
73 RS 1189
81 924 Carrera GTS
69S 2L HSR
70 914/6 2.5 L HSR
2008 GT 3 RS
63 AC V8 prototype
63 fuelie vette
62 e type roadster
thanks david. those 195's are really close. you can do acomparison here.
http://www.1010tires.com/TireSizeCal...?action=submit
73 RS 1189
81 924 Carrera GTS
69S 2L HSR
70 914/6 2.5 L HSR
2008 GT 3 RS
63 AC V8 prototype
63 fuelie vette
62 e type roadster
Mark
Consider Avons. I use them on mine. Correct sizes, matching 'vintage' tread pattern and great adhesion (in the dry at least).
Mike
RS#1551(sold)
67S
Early S reg. #681
I use Avons. CR6-ZZ on 7 & 8 inch 15's. 185/70 and 215/60
Mike
Early 911S Registry #880
356 Registry #30248
1973 911S 2.7 RS spec
1973 911T
1964 356C twin plug
1969 Z28
I use Avons. CR6-ZZ. 185/70 and 215/60 on 7 & 8 inch 15's. Look good and great ride. Not cheap though.
Mike
356 Registry #30248
1973 911T
1964 356C twin plug
1969 Z28
Yep, thats exactly them on the picture aboveOriginally Posted by chicagobreezz
Mike
RS#1551(sold)
67S
Early S reg. #681
