Thread: battery-spare area texture
    My car has original paint. I'm currently removing some of the texture in the battery - spare tire area to treat some minor rust . What can I use to recreate the textured look prior to repainting. I intend to undercoat the bare metal with Por 15.
    Thanks in advance,
    Rob
    356Robo
    64 C Coupe #218448(sold)
    70T Targa #9110110416(sold)
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    Rob-
    That texture is Wurth SKS Stonegaurd. You apply it with a Wurth undercoating gun. It's not too hard to reproduce the texture very accurately.
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
    Scott,
    Thanks for the info. The area to be treated is small. Only the area of the battery boxes and the front portion of the trunk area in forward of the gas tank. Is the sprayer necessary and appropriate for such a confined area? Is there a spay can version?
    Thanks again,
    Robo
    356Robo
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    For a small area like you discribe check this site out,
    http://members.aol.com/darryld/912OCT06.htm
    The Wurth undercoat in a rattle can/ spray bomb leaves a smaller texture which by itself will stand out.
    The Wurth SKS does match the origional texture well, but it's messy and the gun is just another expence, and that's if you have a compressor.
    May 2003
    Eugene, Oregon
    Good info from Classic. The Wurth stuff is water based, so you can fiddle with it a bit without much worry.
    ’15 VW GTI
    '70 911E, Sold
  1. Paint spec needed for battery box area behind horn grills
    By mobius911 in forum Technical Info
    Last Post: 02-04-2013, 07:05 PM
  2. Correct texture and color?
    By FL-Frank in forum General Info
    Last Post: 07-05-2011, 01:17 PM
  3. 71 finish/texture/colors
    By 911E&26R in forum Technical Info
    Last Post: 07-24-2010, 04:56 PM
  4. 72 front hood texture?
    By robmog in forum General Info
    Last Post: 10-02-2008, 09:01 PM
  5. 71e rocker texture????
    By X-Faktory in forum Technical Info
    Last Post: 09-12-2007, 05:10 AM
