Thread: Source for matching wire.
    Senior Member gtgroupe3's Avatar
    Sep 2006
    MD
    I am in the process of twisting a few new wiring harnesses for a fog light, and blower (’67). I would prefer to make them a close to the original as I can, but have had very little luck locating some of the “correct” colors (i.e., white/yellow, red/white).
    Any sources?
    Thanks in advance.
    Sumner
    Registry Member #970
    1970 914-6
    Adriatic Blue
    1972 911T (vice)
    Gemini Metallic
    1967 911S (vice)
    Slate Grey
    Metric Wire
    Try Eagleday.com
    they use to sell metric wire in the correct size, colors and the correct tracer color by the meter.
    (If I had found them earlier it would have saved cutting up good harness' to restore what's in the car).
    Bob
    Early S Reg #370
    Donor harnesses have been the best way to go for me.
    Before these cars were off the charts in value, for years I'd buy complete harnesses from parted out cars.
    I have found them an invaluable source of original wire to make proper repairs and even custom harnesses.
    914 4 cyl cars were the best since the used all the same colors as 911s and there were a lot made.
    I tried to source wire from Germany years ago and found it to be very frustrating
    You can still get proper connectors from there however.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Sep 2006
    MD
    Thank Much
    It looks like Eagleday.com look like the place to be. I have been sparingly using a harness to replace things here and there. It came out of 302511 so it is a bit too early for my '67 but serviceable.
    I’m sure the ’65-66 police will be on my ass, and yes I do know where the carcass is resting.
    Does anyone by chance know the proper metric sizes for the wires; my SWAG would be 2.0mm2 for everything (we’re talking fog and blower) but the fuse panel lead for the blower or gas heater.
    slb
    Sumner
    1970 914-6
    Adriatic Blue
    1972 911T (vice)
    Gemini Metallic
    1967 911S (vice)
    Slate Grey
  1. 1969 911s value matching numbers vs non matching
    By frankmar in forum General Info
    Last Post: 02-26-2015, 09:53 AM
  2. Replies: 1
    Last Post: 06-17-2013, 10:37 AM
  3. Wire harness source?
    Last Post: 09-27-2012, 11:42 AM
  4. MFI wire, ashtray
    By mjk911 in forum For Sale: 911 Parts
    Last Post: 10-02-2008, 09:57 AM
  5. Where does this wire go?
    Last Post: 05-17-2007, 10:43 AM
