Results 1 to 10 of 16
Thread: Paint Code Questions 6080 H
    Hey guys I just purchased a 71 Coupe and it now is in Guards Red (go figure), however the original Paint Code is 6080 H. I can't find any trace of the original color on the car just curious if anyone has seen that color before. I've looked through all my books and haven't found one reference to 6080 so its a special order or to customer provided sample.
    Thanks for the tips!
    JW
    72T Coupe - hotrod.
    72S "Tangie"
    73S Poop Brown
    69T Irish Green
    69S Secret Project
    S Registry Dues Paying member #1438
    Oct 2008
    Burford, ON, Canada
    A photo of the paint code would help me, however, is 8080 (silver metallic) a possibility?
    I will get a picture, but it is :
    6080 H
    that is all that is stamped on the door tag!
    Thanks again,
    Jon W.
    72T Coupe - hotrod.
    72S "Tangie"
    73S Poop Brown
    69T Irish Green
    69S Secret Project
    Here are the pictures of the car at the shop.
    Right now the car is at the shop getting a quick once over, it has sat for close to 10 years. It cleaned up very very nice. Runs good as well.
    The good :
    Very Solid
    Nice Paint although incorrect
    Great complete and original interior minus the steering wheel
    Metal S Spoiler
    Factory Air works
    Weber Carbs
    3000$ Tranny rebuild when put in storage have receipts
    68k actual milage car.
    Front suspension pan replaced at some time very very well.
    The Bad :
    Wale-tail bolted on the factory decklid and done very poorly.
    7 and 8s Fuchs from an SC
    Blacked out trim
    Window Tint
    We are going to pull the engine and install a new base gasket on #3 , leaking for some reason.
    Im not quite sure how to tackle it at the moment, removing the tail will help then slowly bring the exterior back to original.
    There are a few spots that need attention which are surprising becuase it is such a solid car. But a little metal work around the front trunk seal channel. Magnet test was clean all around.
    Can't seem to upload pictures right now. I will try in a little bit.
    JW
    72T Coupe - hotrod.
    72S "Tangie"
    73S Poop Brown
    69T Irish Green
    69S Secret Project
    here are some pictures of the car.
    72T Coupe - hotrod.
    72S "Tangie"
    73S Poop Brown
    69T Irish Green
    69S Secret Project
    Oct 2008
    Burford, ON, Canada
    If you went strictly by 6080 that would indicate a Gulf Blue body and Silver metallic roof; ie: a two tone combo. Even then, 60 is a 1973 color code for Gulf blue according to my notes. Further, I don't know of any two tone combos.
    Very interesting, I dont know what else to tell you but thats what the tag says.
    Thanks for the info Dave! I appreciate it.
    JW
    72T Coupe - hotrod.
    72S "Tangie"
    73S Poop Brown
    69T Irish Green
    69S Secret Project
    Great idea, I will do that!!
    JW
    72T Coupe - hotrod.
    72S "Tangie"
    73S Poop Brown
    69T Irish Green
    69S Secret Project
    Maybe someone here would be able to help?
    http://www.356-911.com/modelinfo/911...olours7173.htm
    Seems to be a custom order. How would one decipher a blend-to-color request? Contact the factory?
    Peter Kane
    '72 911S Targa
    Oct 2008
    Burford, ON, Canada
    Until we see a photo of the data plate showing the paint code, and perhaps get a report on what the original color might have been, it is rather useless to speculate. A COA would tell the tale. I rather suspect it is 8080. It could be poorly stamped, or just a factory typo. It is not the right code for a custom color.
  1. COA Code Questions ('72 T)
    By Ned911 in forum Technical Info
    Last Post: 05-14-2012, 11:17 AM
  2. '67 911S Info wanted/paint code/questions
    By RSK in forum General Info
    Last Post: 10-30-2011, 05:20 PM
  3. Wanted: paint code plate w/ Conda green code
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 11-05-2009, 07:33 PM
  4. how do I remove paint from paint code plate?
    By 911scfanatic in forum Technical Info
    Last Post: 10-26-2005, 06:00 AM
  5. Code Questions....1966
    By 69Sman in forum General Info
    Last Post: 11-16-2004, 12:13 PM
