Results 1 to 10 of 17
Thread: 67S factory weight savings? How and where?
    I've read from several sources (cheap books, magazines, etc.) that a 67S is supposedly lighter than a 67N. I can't figure out where the factory would've saved weight so I am assuming this is probably misinformation.
    Or is it somehow true?
    Just curious and not finding it on the search function.
    Jim
    Dec 2006
    Las Cruces, New Mexico
    Factory lists both 67N & 67S @ 1080 KG.
    Early 911S member #166
    That's what I thought. I found the reference of 154lb weight savings for the S in a book by Patrick Paternie "Porsche 911". Didn't think it could be right given the similar construction, etc. of the cars.
    so a 67S weighs 2376lbs according to factory literature? Seems lighter than that when I push it around my garage...
    Thanks for the info
    Restoration newbie.
    Jun 2007
    San Francisco
    Rally kit buyers had the "bumper refinforcements" (read iron weights)
    deleted. I think these weighed 10kg.
    Do Fuchs weigh less than steelies? They were standard on the S and
    optional on the normal.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    '69 911S was 995 kg [coupe]
    but why was it lighter than other std. models?
    it had MFI, which is heavier than carbs
    it had 6" Fuchs?, which are heavier than the Mag gas burners
    - so where were the wt. reductions?
    Senior Member Milou's Avatar
    Mar 2006
    Geneva
    Wink same chassis, same weight....
    My understanding was that all chassis were exactly the same whether 912, 911T, E, or, S...
    Milou / Registry #884
    www.ecurielyford.com
    Jul 2006
    Switzerland
    Quote Originally Posted by 37yrold911
    1969 serie B:
    -(all models) crankcase cast in magnesium alloy rather than aluminium
    -(all models) transmission housing in magnesium
    -S brake calipers made in light alloy rather than cast-iron
    -S w aluminum engine cover
    -S, E models w biral cylinders and T w cast iron
    Registry member No.773
    but if it goes w/ vented rotors the brake set up might be more.
    Also do S models have rear sway bars which add a few lbs?
    Richard
    what other 901 trans. had mag case?
    surely the typ 911 in '70 weighed more...
    re the mag crankcase, when did that start?
    the 2.2L motors also had mag cases but maybe they had heavier cranks(?) -- i can never keep straight when they bored the motors vs. when they stroked them...
    and when did al calipers start?
    Jul 2006
    Switzerland
    -1968 911T models had heavier camshaft rockers than E, S.
    -MY 1969 911 models started with mag cases.
    -Having the transmission housing in magnesium (MY mid1969) saved 11kg/24lb alone.
    -The 70T still had cast-iron calipers, while E ,S (since 67) had alloy.
  1. FS: Factory Light Weight seats complete
    By georgepvalerio in forum For Sale: 911 Parts
    Last Post: 07-10-2013, 07:40 PM
  2. FS: Factory Light Weight seats complete
    By georgepvalerio in forum For Sale/Wanted: Other Porsche Cars and Parts
  3. FS: RS & RSR light weight seats FACTORY
    Last Post: 05-20-2013, 08:33 PM
  4. FS: RS light weight seats FACTORY
    Last Post: 03-14-2013, 10:57 AM
  5. FS / 1989 911 Carrera 4 Factory Light Weight
    By Lady911 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 10-21-2005, 05:31 AM
