Results 1 to 7 of 7
Thread: 73 911T Metallic Champagne Color Code
    Hello Everyone, This is my first post and currently I do not own a 911T. I'm in the process of purchasing one and once I do I will post pictures.
    I came accross a 73 and according to the seller, the exterior paint is Metallic Champagne. I've done much research and cannot find the color code for 1973. In fact, the only metallic champagne color that I found was for Porsche 912's and it was offered as a special color in 1976 (color code 514-9-3).
    Can anyone shed some light on this issue. Was metallic champagne offered as a special order color for 1973 911T's? If so, whats the color code?
    Sep 2006
    Maryland
    Champagne Yellow is a Porsche color, but not metallic, and not in 1973.
    http://www.356-911.com/modelinfo/911...olours7173.htm
    Rob Abbott
    Rob, thanks for the quick reply. Metallic Champaign is a Porsche 912 color. Is it possible that this might have been an option for 911's?? Attached is a link to Hemmings showing a "metallic champaign" 911t.
    Sep 2006
    Maryland
    It was probably repainted with a later color. Ask them to check the paint code on the inner door frame.
    Rob Abbott
    Seattle WA
    I'm going to go out on a small limb here, but here's a 73 911T (coupe) in grey beige metallic, which for all the world looks like "champagne metallic".
    It says that 4 cars were painted this color...but could have been more. I recall seeing a 73T targa in this color in California back in the late 80's.
    http://www.theaircooledguys.com/Inve...1/Default.aspx
    regards,
    Eric
    There is another possibility
    Silver cars used a two stage Glasurit paint. It is common for the original clear coats to age to a yellow tint causing the overall color to appear as champagne. Then when the car had a repaint the paint shop matched the existing color so the jambs would match. My 71 T is this way, it has original jambs, but has been painted a champagne color to match. If you look inside the door shell where there isn't any clearcoat the color is clearly silver. I bet this is the case with the car you are looking at.
    Chad
  1. Replies: 5
    Last Post: 04-03-2014, 05:18 PM
  2. 1973 911T Metallic Blue!
    By Varooom in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 04-11-2012, 01:17 PM
  3. Replies: 2
    Last Post: 11-16-2011, 07:46 PM
  4. Gold Metallic 1972 911T
    By M491 in forum Technical Info
    Last Post: 03-16-2008, 06:18 PM
  5. Color Code 4610 on a 1971 911T/ Tan interior??
    By tommybarlow23 in forum Technical Info
    Last Post: 03-04-2008, 02:00 AM
