Results 1 to 7 of 7
Thread: Exaust differences? 69 E Targa MFI
    I'm reading about exausts and see there are two listings for my 69 E. One for carbs and another for MFI equiped.
    What is the difference between the two?
    The car currently has thermal reactors on it (PO install) on a 2.0L engine
    What should I be looking for to replace them with?
    Card carryin' member! mjmoran's Avatar
    Aug 2003
    You should get those TEs off your car. Especially with the MFI...
    Look at SSI heat exchangers.
    Michael
    72 911S Coupe, Sepia Brown
    Quote Originally Posted by mjmoran
    that's the plan, to loose the TE's, but after buying the car and all the parts it needed the budjet is broken for a bit to afford the SSI's.
    I see ad's for HE's...some say for carb's other say they will fit. How do I tell what will fit?
    What's different between HE's for MFI cars and carbs?
    Don't want to buy a pig in a poke...
    Aug 2003
    They should be basically the same (pre 75). Make sure that the LHS exchanger has the port for the pre-heat hose that goes to the MFI pump opened. You may have to take out the plug. Be careful of old HE's as they may have holes to add CO in the passenger compartment.
    Michael
    Thanks, that's what I needed to know. I looked at the ones off my buddys 68S and they had the plug in the pipe. Not having proper ones to compare them to makes a difference when you don't know a lot about 911's
    Nov 2003
    Sydney
    GWN,
    This is the port Michael is talking about.
    The pipe goes through the tinware on the lhs of the engine compartment to the mfi pump.
    If its not connected,then the pump will operate at full rich.
    HTH,
    Dennis.
    S Registry member 536
    Thanks Dennis,
    I looked at the ones off my buddys 68 S and his have the pipe which is blocked off.
    I guess my next question is how is it hooked up to the MFI? Pressure fit to the pipe on the HE's?
    It currently isn't hooked up.
    Car was a "barn find" parked for 15 years.
  1. Value differences T vs S
    By RS-GT in forum General Info
    Last Post: 06-13-2014, 09:31 AM
  2. B&B exaust muffler
    By 72MFI in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 11-06-2011, 12:16 PM
  3. Differences in 993 from 95-98?
    By Sacto S in forum Off Topic
    Last Post: 09-25-2008, 10:53 AM
  4. targa door differences
    By neilk in forum General Info
    Last Post: 03-23-2004, 04:41 PM
  5. 2.4S vs. 2.2S MFI -- DIFFERENCES?
    By NeedanEarlyS in forum Technical Info
    Last Post: 12-15-2003, 03:06 AM
