Results 1 to 9 of 9
Thread: thin sheet metal on 911 RS
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    attached is something that has been around for a while on various forums.
    I picked it off DDK recently, but it relates to a 1982 UK Carrera RS Register (part of Porsche club of GB) document following a meeting with the factory at that time.
    It shows what they say the factory suggests is the weight savings of the thinner panels. However note the comment at the bottom from the author of the newsletter.
    Since then a lot more has been learned about these cars and a lot more information released by the factory including for the RS book
    However i think this almost contemporary account is very interesting
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    The Netherlands
    RS panels
    I always thought that the normal steel had a thickness of 0.88 mm but same grade. Not 1-1.25 mm as mentioned in the PP thread. If you divide the weights form Hugh's table then you come pretty close to 0.88 mm.
    Cees
    .88? interesting - that wouldn't be much difference in stiffness
    it should quite easy to measure though
    RS Sheet Metal Thicknesses
    I've heard/read somewhere about thinner sheet metal being used by Porsche for the homologation of the Carrera RS. As I recall, these 'light-weight' panels were used for fabrication of the 1st + 2nd series cars, to be replaced by 'standard' 911 pieces as the thinner-gauge bits ran out
    This is the first documentation that I've come across to given specific figures on any weight differences
    What's funny is . . . Porsche was offering 'light weight' RS quarter panels, not that long ago
    Anyway . . .
    Has anyone ever measured the metal thickness of any RS panels to confirm this?
    Has anyone ever weighed an RS to find out the actual weight?
    Don't know about the weight savings or thickness. But the difference in price was enough to tighten my pocket so to speak. Just ordered a set of rear RS quarters. Price on the regular RS quarter was about $2,200 ea. The thin light weight quarter was up about $8,200ea, and yes I did fall off my Snap-on stool. I could not think that you would save more than 4-5 pounds of weight each. Dealership could not give me a shipping weight for the different Quarters. The dollar difference was enough for my decision.
    Bill Barnich
    R Gruppe Nr.230
    Early S Nr.960
    71 911T/2.7 Tangarine
    73 911?/3.6 work in progress
    Apr 2003
    NoCal
    There is a fair amount of information on previous threads here. I doubt you will find anyone that measured it, but it is quite obvious IF you own the particular car by simply pushing against the various panels. With the roof it is rather dramatic and makes a regular 911 seem like a Mercedes. BTW, the thinner panels have been found well past the stated cars. It's all here .. somewhere.
    JR
    I believe the 993GT2's or 911GT's used thinner guage steel throughout the shell.
    early S registry # 2596
    Thin-gauge Panels . . .
    . . . another thread . . .
    http://www.early911sregistry.org/for...ighlight=stout
  1. WTB: NOS Sheet Metal
    By 50/50 in forum For Sale: 911 Parts
    Last Post: 01-07-2014, 06:21 AM
  2. Porsche Classic - RS Thin Sheet Panels
    By nickd in forum Technical Info
    Last Post: 07-07-2013, 03:02 PM
  3. need sheet metal
    By misterc in forum Technical Info
    Last Post: 05-31-2011, 01:59 PM
  4. 911 Sheet metal Help
    Last Post: 05-29-2006, 05:56 PM
