Thread: advice on correct exhaust color 1972 911T
    My 1972 911T Coupe is in dire need to have the exhaust system repainted or recoated.
    I believe the exhaust was originally white from the factory. I would like to verify this.
    I would also like forum opinions on what to use. I would prefer to repaint it first using a high grade high temp paint vs. high temp jet coating.
    I don't want to deviate from the original factory exhaust color.
    Thanks in advance.
    Peter Perry
    1972 911T Coupe Albert Blue
    1965 230SL
    Lightbulb
    Peter,
    The factory was NOT white......
    It was a medium dark gray.....
    this might help....
    http://www.early911sregistry.org/for...=exhaust+color
    Cheers
    Thank You
    Peter,
    this might help....
    Cheers
    Chuck.
    Thank you for answering my question. You have sent me in the right direction.
    Peter Perry
    1965 230SL
  1. Replies: 3
    Last Post: 01-08-2013, 05:29 PM
  2. Replies: 9
    Last Post: 09-13-2012, 06:38 AM
  3. Correct exhaust paint color on 72 911
    By Perry911 in forum Technical Info
    Last Post: 04-11-2010, 02:54 AM
  4. correct tire size for 1972 911T
    Last Post: 01-11-2009, 04:11 AM
  5. Correct heat exchanger and exhaust color -1966 Normal
    By 304065 in forum Technical Info
    Last Post: 10-23-2008, 06:38 AM
